SEARS AGM battery help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 08-22-2010, 01:28 AM Thread Starter
dirtrack650's Avatar
Question SEARS AGM battery help
Tried to start the bike today but the battery was dead. Rode it just a few days ago with no problems w/good voltage. Key was off and removed, nothing was on.
Frustrated with the AGM battery - I took it out, checked voltage 8.6 and falling slowly. Knowing the problems with low acid level in a wet cell, I pried off the caps on the 'sealed' AGM battery.
Looking in the holes, the glass mats were dry. I added water, waited + or - 10 minutes, checked voltage ... and 12.8 w/o charging.
The battery is charging at 1 amp for a few hours, I'll try it in the morning.
Anyone else ever seen this or take the caps off a sealed battery?
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #2 of 14 (permalink) Old 08-22-2010, 01:36 AM
baldy's Avatar
I'm not totally sold on the idea of a sealed battery except for the fact it eliminates the seepage problem. How old is the battery?
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #3 of 14 (permalink) Old 08-22-2010, 01:31 PM Thread Starter
18 months? I wonder if my R/R is overcharging. I did some research on charging AGM's. They are much more sensitive to overcharging than lead acid types.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #4 of 14 (permalink) Old 08-22-2010, 04:42 PM
Heading to the DARKSIDE!
BRET H's Avatar
I have that same battery in my bike...for about a year now. My R/R started going bad. It would not regulate the voltage when the bike was started and would go up to as high as 19.4V. After running for about 5 min the regulator would click and start working fine after that. The whole time I had that regulator on my bike it would charge at 13.8-14.5V. I replaced it recently with a Ricks Motorsport regulator ($98.00) from Dennis Kirk and it will not charge any higher than 13.5V. My AGM Sears battery has worked flawlessly through all of that. I think maybe your regulator my be going out and overcharging the battery at 14-15V? The charge does not need to be any higher than 13.5V ever! Is your reg. still over the Goat or has it been relocated or degoated? I hope this helps.....Oh yeah my bike is an '86 with a new Ricks Motorsport stator too as of a year ago.
BRET H is offline
post #5 of 14 (permalink) Old 08-22-2010, 06:29 PM
Love My Baby
rubyrick's Avatar
I've got a Sears AGM battery too, 2 years now and running well. What kind of charger are you using? How often are you charging it? I had a problem with my wet cell when I was trickle charging daily, seems each time you connect the charger the charging voltage starts high before it goes into trickle mode, and that was enough to loose a little fluid thru the vent tube. But on an AGM MF battery, there's no vent tube. I have only charged my AGM battery four times in two years, and only because I hadn't rode the bike in a while and the resting voltage was a touch lower, but still above 12 volts. You could be overcharging or your R/R could be out.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #6 of 14 (permalink) Old 08-23-2010, 12:12 AM
engine89's Avatar
I'm still going with my theory that these higher voltage AGM batteries are causing more heat to be generated in the R/R by shunting more power to ground, leading to R/R failure and taking the stator with it by association.
engine89 is offline
post #7 of 14 (permalink) Old 08-23-2010, 01:02 PM
MANIC MECHANIC
vulcanjoe's Avatar
the stators were going bad before the AGM batteries were widely used.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #8 of 14 (permalink) Old 08-23-2010, 10:41 PM
engine89's Avatar
I'm sure they go bad on every bike eventually. I'm just trying to gauge if there is a link between AGM and early R/R failure. My 1990 is still going strong on the origional stator and R/R. I'm reading about alot of stator failures on this site and a good number are on newer bikes that switched to AGM. Many on this site refuse to even give this possibility any thought.
engine89 is offline
post #9 of 14 (permalink) Old 08-24-2010, 12:26 AM
MANIC MECHANIC
vulcanjoe's Avatar
If you maintain a wet cell battery properly and keep electrical connections clean or keep the bike inside a wet cell would be fine. but most don't.
34k so far
coastered
spline lube
TPE stator
post #10 of 14 (permalink) Old 08-24-2010, 12:40 AM
flitecontrol's Avatar
I've put 11,000 miles on my 1989 since installing an AGM. Original stator and R/R
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
Tags
agm dead battery
