bevel gear - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 08-18-2010, 10:42 PM Thread Starter
tickman's Avatar
bevel gear
I'm getting ready to change my stator in my 04, just need to order gaskets last thing to do ,and in the the motor tilting process is the bevel gear attached to the drive shaft and is it necessary remove, I'm not wanting to take it off to much. A little nerves sorry.
tickman is offline
post #2 of 3 (permalink) Old 08-18-2010, 11:26 PM
Here is wibs writeup for the stator replacement.
https://www.vn750.com/forum/showthread.php?t=11369
According to this, the bevel gear does have to come off.
post #3 of 3 (permalink) Old 08-19-2010, 06:58 PM
Concert connoisseur
wib714's Avatar
and if I remember correctly it is just the few bolts holding it on, no gaskets and just the rubber boot to slip off the rear of it. keep the opened side up though (side that is mounted to the bike) cause there is a small gear in there that will just fall out that the clutch cable hooks too I believe and you will have to reposition it. no major prob if it does fall out though. grease your shaft splines while our in therewith moly 60 too!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
