Dead as a door nail.... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 08-09-2010, 06:02 PM Thread Starter
...wonder where that expression came from?
When I returned to work after lunch, I shut the bike down normally. When I came back out to start it up....nothing. No lights, indicators, sound...nothing!
Long story short, I needed to move the bike slightly (while in gear) to get the oil & neutral lights to come on...it then started easily/normally.
What, if anything, was out of alignment?
VoIPDoc is offline
post #2 of 13 (permalink) Old 08-09-2010, 07:00 PM
fergy's Avatar
Sounds like what ever shaking you did might have made contact with whatever electrical connection might be loose. I'd start by checking engine grounds and battery connections for looseness and corrosion. Might also be your ignition switch that is flaky. I had the same thing happen but on a 1980 KZ550 that had corrosion in every electrical connection that I eventually found...
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 13 (permalink) Old 08-09-2010, 07:27 PM
http://www.worldwidewords.org/qa/qa-dea1.htm
post #4 of 13 (permalink) Old 08-09-2010, 07:49 PM Thread Starter
Doug,
Seemed to be related to slight engine rotation as a result of moving the bike. Perhaps a starter sticking??
I'm fairly sure it's not the ignition switch....heck, it's never been in the rain or left outside over night.
VoIPDoc is offline
post #5 of 13 (permalink) Old 08-09-2010, 07:50 PM Thread Starter
Thanks KM....good explanation as any I guess
VoIPDoc is offline
post #6 of 13 (permalink) Old 08-09-2010, 11:35 PM
I just bought the kz400. The young man that I got it from could not start it. I advised him to check all main connections. He said he had. He gave up and sold it to me. When I got home I found that the ground cable was loose at the frame. Tightened it up and every thing works good now.
post #7 of 13 (permalink) Old 08-10-2010, 12:04 AM
baldy's Avatar
Doug,
If it was the starter sticking you would at least have had lights. I would say it is something electrical and the switch would be the 1st place I would look and then to the battery and all ground connections as fergy said.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #8 of 13 (permalink) Old 08-10-2010, 10:50 AM
flitecontrol's Avatar
Not sure if it's the same problem I experienced yesterday or not. Bike was running as I duckwalked it backwards out of the garage and it died. No lights, nothing. Pulled the cover to check fuses and they were all good. Noticed some wires above and to the left of the fuse box and found the red one was almost off the connection. Pushed it back on and she fired right up.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #9 of 13 (permalink) Old 08-10-2010, 10:56 AM
baldy's Avatar
That sounds like it was the coil pack wire.
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
post #10 of 13 (permalink) Old 08-10-2010, 11:35 AM
fergy's Avatar
Electrical problems can be so fickled that it always pays to start with the simple stuff. It is easier to check grounds and connections so that's where I would start. Just like the KZ400 above, it is usually that simple. My KZ550, a 1980 that had been outside most of its life by the looks of it, decided not to start one day at lunch. I kept a volt meter in my gear so I pulled it out and started checking. I had 6 volts showing on a 12 volt main wire in the headlight bucket so I knew it was probably corrosion somewhere causing a weak connection. I went straight to the battery to start checking. I found it on a small bullet connector on a wire that was coming off the positive battery cable. When I pulled the bullet connector apart, white powder dumped out of it. I cleaned it up with a sheet rock screw (only tool I could find) and put it back and she started right up. At home I replaced the connector before going back to work...
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
