Signal light replacement - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 08-07-2010, 10:30 AM Thread Starter
IBEW 915 Electrician
hctublerub's Avatar
The rubber shock mounts on my signal lights are deteriorating so I went looking for the new rubber. It seems the signal light is a whole assembly and you have to buy the whole thing.
Is it possible to buy just the rubber? May as well upgrade to LED's while I'm at it.
'01 Vulcan 750
Irridium Plugs
hctublerub is offline
post #2 of 14 (permalink) Old 08-07-2010, 10:35 AM
flitecontrol's Avatar
There's a thread here about a member using the barrels from Bic pens to fix his deteriorating rubbers. Just noticed mine are starting to crack too.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 14 (permalink) Old 08-07-2010, 11:02 AM
Nope, the rubber parts are not available separately.
post #4 of 14 (permalink) Old 08-07-2010, 11:10 AM
baldy's Avatar
If you have to get new lights you might as well go with an LED.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #5 of 14 (permalink) Old 08-07-2010, 10:05 PM Thread Starter
hctublerub's Avatar
Did find the bic pen solution.
http://twofoos.com/index.php/8/vulca...signal-repair/
'01 Vulcan 750
Irridium Plugs
post #6 of 14 (permalink) Old 08-07-2010, 10:10 PM
now why isn't this cheap fix in my DIY guide? no clue, but going to add it.. lol
post #7 of 14 (permalink) Old 08-07-2010, 10:29 PM
1985 VN-700
L2fish's Avatar
Ive done 3 of 4. Dennis Kirk 29 dollars. Rubber is not as good as factory. I am thinking of slipping plastic tube in mine so they dont sag down.
L2fish is offline
post #8 of 14 (permalink) Old 08-07-2010, 10:43 PM
Good DIY fix to remember, even if it is only temporary or for an emergency.
post #9 of 14 (permalink) Old 08-08-2010, 07:11 AM
Columbus, Ohio
jimkonst's Avatar
I wonder if you could use copper tubing, instead. You would have to insulate carefully, but it would be stronger. Maybe the bic is strong enough.
Jim
'95 Kawasaki Concours
Sold my Vulcan
I do LOTS of dumb stuff. Riding is only one of them.
jimkonst is offline
post #10 of 14 (permalink) Old 08-08-2010, 10:54 AM Thread Starter
hctublerub's Avatar
All mine show signs of decay but one is so decayed that it can't be stiffened. Wonder if it's possible to create a mold whereby you can pour some type of rubber compound.
'01 Vulcan 750
Irridium Plugs
