Tail Light Problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 08-07-2010, 10:18 AM Thread Starter
Tail Light Problem
Every time I turn my key on the tail light fuse blows out. I can't figure it out, the tail light is hooked up correctly and I can't figure out what is blowing the fuse. Do you guys have any idea of what I can check to figure this out? It's getting really annoying. I can't ride my bike at night because my running light doesn't work. The brake lights work fine, it's just the running light. Help!
duhstee is offline
post #2 of 6 (permalink) Old 08-07-2010, 10:38 AM
flitecontrol's Avatar
Sounds like a short somewhere. Have you checked to see if a wire under the seat may have gotten crushed or have worn insullation?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 6 (permalink) Old 08-07-2010, 11:00 AM
Have you checked the fuses??
post #4 of 6 (permalink) Old 08-07-2010, 12:53 PM
Could be the running lights, tail light or license plate light. First disconnect them all - blue wires to the running lights in the front turn signals, red wires to the rear light and license plate light.
Then switch on ignition. If the fuse blows, check the wiring harness as flitecontrol said. If not, start reconnecting the wires. When the fuse blows you know where to look for a short.
pappa is offline
post #5 of 6 (permalink) Old 08-07-2010, 02:04 PM
MANIC MECHANIC
vulcanjoe's Avatar
I would unhook the rear harness and check for continuity to ground on the red wire. if there is your short is in the rear harness. if not it is between the jb and the rear connector.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #6 of 6 (permalink) Old 09-16-2010, 09:56 AM Thread Starter
Finally found it. Turns out it was my license plate light blowing the fuse. I unhooked it and all the other lights work. huzzah!
duhstee is offline
