Battery Strap Question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 08-03-2010, 01:53 PM Thread Starter
Rider on the Storm
EasyRector's Avatar
Question Battery Strap Question
I just replaced my dead Yuasa MF battery with a Diehard Gold MF battery. The battery seems to be working perfectly.
Here's my problem: the battery strap doesn't fit completely over the new battery. There's a ridge on the top of the new battery that makes it impossible for me to hook the forward latch and screw it in to the battery box.
For the moment, I've simply screwed the strap in to the battery box. The strap hangs over the battery and seems to hold it fairly snug. (Close, but no cigar.) But, obviously, it's not nearly as snug as it would be if it was both hooked and screwed in.
Can I leave it like this? Or do I need to work out a more secure solution?
Does anyone else have a similar issue with the Diehard?
EZC
EasyRector is offline
post #2 of 6 (permalink) Old 08-03-2010, 02:09 PM
baldy's Avatar
I ran mine for several hundred miles before I noticed it didn't have the battery strap. It basically just keeps it from moving around so it doesn't wear a hole in the battery. You could try a short rubber bungy strap to hold it or maybe even the rubber strap that is in the tool box would work.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #3 of 6 (permalink) Old 08-03-2010, 02:42 PM
cglennon's Avatar
I had the same problem switching from a Yuasa wet cell to Yuasa AGM. The battery slid from side to side until the negative cable came loose and the bike stalled. I ended up bowing the battery tie down a bit and adding a shim, made from rolled cardboard.
Chris Glennon - Portland, OR
cglennon is offline
post #4 of 6 (permalink) Old 08-03-2010, 03:03 PM Thread Starter
Rider on the Storm
EasyRector's Avatar
I just read, in an old post, that someone else had the same problem with the Diehard. He said that the battery came with a spacer attached to the bottom with two-sided tape ~ when he pried it off, it fit. I didn't even notice a spacer on the bottom of the battery. I hate to pull it to check, but it will be worth it to have it fit properly.
EZC
post #5 of 6 (permalink) Old 08-03-2010, 05:34 PM Thread Starter
Rider on the Storm
EasyRector's Avatar
Thumbs up I Love This Site!
Clicking through previous posts, I read that there was a spacer on the Diehard battery that could be removed (never noticed it when I installed it). I saw it was so, and removed it. In moments, problem solved!
EZC
post #6 of 6 (permalink) Old 08-03-2010, 09:56 PM
Love My Baby
rubyrick's Avatar
I was JUST going to post that info to you when I read it on the last post. Glad you found it. BTW, I've had the same Sears battery in my baby for 25 months now it it's going super strong. I know this could change literally overnight, especially getting beyond the 2-year mark. But it's been extremely good to me so far.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
