brake handel - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 08-02-2010, 06:17 PM Thread Starter
gun slinger
centurynick's Avatar
brake handel
found out my brake handel has some slop in it and while cruiseing the brake lamp flashes . there a bushing or some sort of adjustment i can do too tighten it up so the lamp stops flashing
2010' voyager
2005 1600 nomad sold
1987 kawasaki vulcan 750 SOLD
1985 kawasaki vulcan 700 parts bike maybe
lots of hand guns
3 cagers doors kicked in
centurynick is offline
post #2 of 10 (permalink) Old 08-02-2010, 06:26 PM
Cheman's Avatar
the brake handle pushes on a plunger and a spring. The spring wears out. They are sold together. Replace and your problem will go away, At least it did for me.
Cheman
1986
Purchased 7/03 w/13000 mi
Sold10/10 27,000miles
Ear shave
V&H Cruisers
Tim Parrott stator
Iridium Plugs
AGM Battery
Splines lubed
Clear Alternative LED brake light
TOC mcct
Mutazu LN Hard saddlebags
Chad's floorboards
Current ride-2009 Honda VTX1300
Cheman is offline
post #3 of 10 (permalink) Old 08-03-2010, 12:53 AM Thread Starter
gun slinger
can you show me what part is needed ????
2010' voyager
lots of hand guns
post #4 of 10 (permalink) Old 08-03-2010, 01:16 AM
Cheman's Avatar
http://tinyurl.com/24ndjqj
43020 PISTON-COMP-BRAKE
1986
Ear shave
V&H Cruisers
Tim Parrott stator
Iridium Plugs
AGM Battery
Splines lubed
TOC mcct
Chad's floorboards
Cheman is offline
post #5 of 10 (permalink) Old 08-03-2010, 01:34 AM
Cheman's Avatar
What happens is, due to use, the spring becomes compressed, and will not push the handle back out all the way to the hard stop. This allows the slop and the intermittent activation of the switch causing the brake light to flicker on and off. My old spring was visually shorter than the replacement due to the compression. Being as your bike is 23 years old, it is a good idea to replace the piston(plunger). In my 86, the rubber on the plunger was very much deteriorated.
Cheman
1986
Ear shave
V&H Cruisers
Tim Parrott stator
Iridium Plugs
AGM Battery
Splines lubed
TOC mcct
Chad's floorboards
Cheman is offline
post #6 of 10 (permalink) Old 08-03-2010, 06:26 AM Thread Starter
gun slinger
ya i orderd that and some brake pads .... i took the front tire off too get a new one and seen the pads were close to needing to be replaced so i figured what the heck lol ........thanks a ton , that site is way better then bikebandits.com hope i get my stuff here shortley !!
2010' voyager
lots of hand guns
post #7 of 10 (permalink) Old 08-03-2010, 10:59 AM
Cheman's Avatar
I have ordered from cheapcycleparts four times. Expect 3 to 5 days to get the order out plus shipping time.
Cheman
1986
Ear shave
V&H Cruisers
Tim Parrott stator
Iridium Plugs
AGM Battery
Splines lubed
TOC mcct
Chad's floorboards
Cheman is offline
post #8 of 10 (permalink) Old 08-13-2010, 11:20 PM Thread Starter
gun slinger
well i did the new plunger and spring and it fixed my problem...... wow easy fix the bike runs great minus the hot starting issue which i will address next .......... thanks !!!!!!!!!!!!
2010' voyager
lots of hand guns
post #9 of 10 (permalink) Old 08-14-2010, 01:16 PM
Cheman's Avatar
Happy for you that that was the problem and you got it fixed.
cheman
1986
Ear shave
V&H Cruisers
Tim Parrott stator
Iridium Plugs
AGM Battery
Splines lubed
TOC mcct
Chad's floorboards
Cheman is offline
post #10 of 10 (permalink) Old 08-14-2010, 02:24 PM Thread Starter
gun slinger
cheman
you weren't kidding that the old spring gets weak and compresses . the new spring was about an inch longer then the old one ...
2010' voyager
lots of hand guns
