charing system - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 07-28-2010, 01:35 PM Thread Starter
charing system
hey all.
i just bought me an 01 750 vulcan as a fixer upper, the charging system doesnt work. i did the ohm check on the stator and they all read good and i did the check to ground and they all read a small amount of ohms like a short on all three wires not just one. but then i did the voltage check when reving up and it goes from about 7-8 volts to up around 18.
what do you all think, is it bad.
any info would be helpfull, thanks
01 750 vulcan
just bought
collom7 is offline
post #2 of 9 (permalink) Old 07-28-2010, 01:48 PM
clock152's Avatar
did you check the R/R?.. this will be your last conection point tot he battery for charging.. our R/R is not the greatest.
clock152 is offline
post #3 of 9 (permalink) Old 07-28-2010, 01:50 PM Thread Starter
i didnt think you could check the r/r, can you? and how?
01 750 vulcan
just bought
collom7 is offline
post #4 of 9 (permalink) Old 07-28-2010, 01:56 PM
clock152's Avatar
I'm sure Slim or Vulcan Joe will chim in here in a bit...Slim has a write up on the testing.. I am not sure where it is.. you can do a search on the R/R testing.
clock152 is offline
post #5 of 9 (permalink) Old 07-28-2010, 01:57 PM
clock152's Avatar
clock152 is offline
post #6 of 9 (permalink) Old 07-29-2010, 02:33 PM
If you did the measurements correct, your stator is bad. There should be no continuity from any of the stator legs to ground, and the AC voltage should be a lot higher.
The stator windings are connected together in a 'star' configuration, and the resistance of each winding is quite low. So if any of the windings is grounded, they all appear to be grounded.
pappa is offline
post #7 of 9 (permalink) Old 07-29-2010, 07:28 PM Thread Starter
thats what i was thinking but i was hoping i was wrong, i also tested my r/r from the stats found on another thread and i think it is bad to. i already ordered the r/r and was going to try it before ordering the stator. if the stator is bad it should'nt hurt the new r/r just to try it right?
01 750 vulcan
just bought
collom7 is offline
post #8 of 9 (permalink) Old 07-29-2010, 08:31 PM
flitecontrol's Avatar
If you haven't read the threads about Ricks stator and R/R, they aren't reliable. If you're in a hurry, buy from Kawasaki. Otherwise, send the old stator to http://www.tpe-usa.com/ to have it rebuilt better than new. May take a while, but that's where mine's going when it craps out.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #9 of 9 (permalink) Old 07-29-2010, 11:19 PM
MANIC MECHANIC
vulcanjoe's Avatar
i agree completely with fc www.tpe-usa.com for the stator and www.roadstercycle.com for the r/r he does send instructions for the retrofit
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
