stator bad ?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 07-23-2010, 07:47 PM Thread Starter
Cool stator bad ??
Hello Everyone,
the other nite while coming home my headlight went out and bike stopped at same time.
I been messing with it today after reading here relentlessly and did the ol blue wire switch on junction box an presto light works.
now for the other... battery was low but got the bike started on its own so put ohm meter on battery and 11.33 at 2 grand 11.58 at 4.
I checked all wires and ground from front to back and check manual from site (thx btw).
i"d love to hear your comments and thx in advance.
BTW... what happens when you check the wires from stator how do you make sure to get them back the same or does it matter??
BroncoII is offline
post #2 of 2 (permalink) Old 07-23-2010, 08:36 PM
first off, the stator leg wires have no order to plug back up between the three.
do you have an mf battery? also charge the battery to 12.5 volts then run test again and see if that helps
