AGM batteries fry stators - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 31 (permalink) Old 07-23-2010, 09:36 AM Thread Starter
engine89's Avatar
Has there been discussion about the possibility that agm batteries fry stators by generating excess heat in the R/R and stator? I just put an agm in my 1990. The headlight is brighter even at low idle and the system has at least 14 volts even at idle. IF the stator keeps cranking out power and it has no place to go, it gets stored as heat. I think I the clock is now ticking for my stator even with the r/r relocation.
engine89 is offline
post #2 of 31 (permalink) Old 07-23-2010, 10:03 AM
fergy's Avatar
I bought my 750 in early 06 and it already had an AGM battery in it, no idea how old. I finally replaced it in early 09 just because it was at least 3 years old, (I'd had it for 3 years) and obviously older and I just felt like I should replace it before it started having any trouble. Put another AGM in the bike and it is still running fine, knock on wood. Never had any stator problems with it, and it has been in Central Texas all it's life, 100+ degree summers and all. I did re-locate my r/r in mid 06. Maybe I got lucky with a good stator, or maybe relocating the r/r truly made some difference in how the electrical components survive--I don't know.
In my opinion, using a wet cell battery puts a strain on the electrical system, and replacing it with an AGM battery (and possibly relocating your r/r) gives your electrical system a "breather".
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 31 (permalink) Old 07-23-2010, 10:06 AM
flitecontrol's Avatar
You could try one of the replacement R/Rs FWIW. Reports are they don't get hot. Thread here in electrical section.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 31 (permalink) Old 07-23-2010, 10:11 AM
baldy's Avatar
A new battery will show higher volts but I don't believe it will hurt anything. Heat and over whellming the stator and r/r will cause problems in the long run, RE; adding more lights and electrical equipment. If you have 14v at idle I would think that your electrical system is working great!
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #5 of 31 (permalink) Old 07-23-2010, 02:48 PM Thread Starter
engine89's Avatar
I'm not an engineer but it seems to me if the stator puts out power at a steady rate and it has no place to go heat will be generated if the battery is pushing power back.
engine89 is offline
post #6 of 31 (permalink) Old 07-23-2010, 02:53 PM
Not an engineer either, but my understanding is the stator's AC output goes directly to the R/R, gets converted to DC, what's needed is sent to the charging/electrical system, and the excess is dissipated as heat by the R/R. Nothing goes "back" to the stator, at least not if the system is working as it should.
"Black Beauty"
Old Blue
post #7 of 31 (permalink) Old 07-23-2010, 03:01 PM Thread Starter
engine89's Avatar
So then a weaker battery or extra lights would be better for the system, more power burned off thus less heat in the R/R . I wish I had checked the temp. of the R/R prior to and then after the battery change.
engine89 is offline
post #8 of 31 (permalink) Old 07-23-2010, 03:11 PM
And there it is....lol
Batteries do not "push power back" .The R/R is supposed to handle excess power, and it does...without sending it back to the stator.
Stators fail for many reasons, but using an efficiant high end batttery is not one of them. The stator by the way does not put out a "steady rate" of power, it actually fluctuates depending on engine speed.
A good stator , puts out 13.7-14.6 volts (after being switched to DC by the R/R) , regardless of what battery you use. The R/R grounds out excess power if need be to the frame, which causes it to get hot...by design...but many still relocate their R/R as it just seems to be in a bad place. If you somehow fry out your R/R it can damage your stator... but most times stators go first. Your R/R is more likely to fry itself due to a bad or shorted out battery than one that actually can take more power...meaning your thinking here is backwards.
post #9 of 31 (permalink) Old 07-23-2010, 03:14 PM
fergy's Avatar
Logically, that makes sense, but I feel like there is more to know about how an r/r works before we could agree on that! I'll bet there is a diode built in to the battery output of the r/r that only allows current to flow toward the battery and not in the opposite direction--just guessing, with my limited knowledge of electronics. Somehow, my guess would be that the larger portion of the heat generated by the r/r is from the conversion of AC current to DC voltage, and the unused energy is a small portion of the heat generated--again my guess. For instance, if you notice, most power adapters will stay relatively cool while plugged into the wall, if nothing is attached to the business end, but once you plug it into the device it is providing and converting power for, it will get several times hotter while in use. I know it is a bad example, but it's all I can come up with!
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #10 of 31 (permalink) Old 07-23-2010, 03:16 PM
clock152's Avatar
I'm pretty sure that the exess power is diverted to the seats butt hammers (buttons) to help maintain a constant discomfort level...I might be wrong though.
clock152 is offline
