dielectric grease - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-19-2010, 01:46 PM Thread Starter
Duffer's Avatar
dielectric grease
Seem to have a few connections problems that are causing engine to cut our when running. I found a couple of loose connections.
It was suggested that I apply dielectric grease to the connections to improve conductivity etc.
Can I use it on the connection blocks to the fuse box and ignitor as well?
Duffer
VROC #26950
Canadian Motorcycle Cruisers Chapter 079
York Region, Ontario
Duffer is offline
post #2 of 4 (permalink) Old 07-19-2010, 01:57 PM
Yahoo VN750 Group Owner
Pick's Avatar
Send a message via Yahoo to Pick
You can use it on any electrical connection; It just prevents corrosion; it doesn't improve conductivity.
Jim "Pick" Foster
Dixon, IL
VROC #9492
2018 Suzuki Burgman 650
2010 Honda NT700V
http://www.flickr.com/photos/jimfost/sets/
http://s186.photobucket.com/albums/x294/jimfost/
Pick is offline
post #3 of 4 (permalink) Old 07-19-2010, 02:45 PM
Vintage bike addict
antiq's Avatar
To improve conductivity clean and tighten the connections. You can gently squeeze the female connectors to tighten the connections. Application of dielectric grease is recommended to keep out moisture that can cause corrosion connection issues.
Eleanor Roosevelt.
antiq is offline
post #4 of 4 (permalink) Old 07-19-2010, 03:55 PM
If your connections are corroded, clean them first with Electronic spray cleaner.
IIRC some body a while back said that electrical contact cleaner will make the plastic holding multiple connectors brittle and break.
When using dielectric grease pack the connector so it will squish out a little,and pack the back of both sides too.
