machine dying - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 07-19-2010, 02:01 AM Thread Starter
Journey's Avatar
machine dying
not sure if this is the right place to post
I have a 1995 VN750
ran great for first week, then starting cutting off while driving. it runs great then just stops.
have tried many fixes so far
new throttle cables
new plugs
worked on choke
cleaned gas tank vent hose and holes
ran seafoam through
bike runs smoothly the a small surge occasionally then it just cuts off.
not dure what else to try please help
Journey is offline
post #2 of 10 (permalink) Old 07-19-2010, 04:51 AM
KIMMERLING's Avatar
Check the right air cleaner hose ...cut it at an angle so that it doesn't close off when sucking air...that might cause intermittent power loss
or it could be electrical...something with the ignition..but i would check the battery cables and make sure its grounded tight.
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #3 of 10 (permalink) Old 07-19-2010, 09:39 AM Thread Starter
Journey's Avatar
where is the right air clleaner hose
Journey is offline
post #4 of 10 (permalink) Old 07-19-2010, 09:42 AM
flitecontrol's Avatar
Its a hose that goes into the right air cleaner. Stock it is cut square and can bottom out against the housing, causing problems. Cut the end of the hose at an angle to prevent this.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #5 of 10 (permalink) Old 07-19-2010, 09:53 AM
clock152's Avatar
also check the kickstand switch...sometimes they go bad.
clock152 is offline
post #6 of 10 (permalink) Old 07-19-2010, 05:42 PM
KIMMERLING's Avatar
Pull the rubber back on the kickstand switch and blast it with wd 40.
Ventura guards
MadStadt mount
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
post #7 of 10 (permalink) Old 07-19-2010, 07:39 PM
Vintage bike addict
antiq's Avatar
Will it restart immediately? If it is electrical it might be the kill switch or one of the safety switches. I'd check the side stand switch first as suggested above though I'm not a big fan of WD40 except as a start spray for two strokes.
Eleanor Roosevelt.
antiq is offline
post #8 of 10 (permalink) Old 07-20-2010, 11:54 PM Thread Starter
Journey's Avatar
I hav e no hose ending in air cleaner other than an oval shaped hard hose about 1 1/2 by three
Journey is offline
post #9 of 10 (permalink) Old 07-21-2010, 01:34 AM
Can`t find a picture, but here is a diagram of where it goes. Cut off end at 45* to prevent bottoming out in air filter box.
https://www.vn750.com/photopost/showp...o=1757&cat=503
post #10 of 10 (permalink) Old 07-21-2010, 02:47 AM
You mentioned you were trying to get the air box out of the way ("earshave" in VN750 lingo). Is it possible this hose, which is about 1/2" to 3/4" in diameter, got pulled off? If you haven't completed the earshave and relocated or plugged (can't remember which you do with an earshave, mine's stock) the hose, it will cause problems.
"Black Beauty"
Old Blue
