Relocated my Regulator! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 07-11-2010, 03:09 AM Thread Starter
'03 VN750 "Rosie"
bstew7890's Avatar
I put mine on an aluminum plate on a bolt that holds the left passenger footrest and the rearmost exhaust support. I didn't have dielectric grease nor do I know what the purpose of it is. I just put it on dry. Am I finished?
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
post #2 of 16 (permalink) Old 07-11-2010, 04:50 AM
KIMMERLING's Avatar
Basically ...as long as its secure. You could clean the contacts with electric contact cleaner then use a little dielectric grease to protect it and put the plug together...then wala!
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #3 of 16 (permalink) Old 07-11-2010, 09:39 AM
Columbus, Ohio
jimkonst's Avatar
You could make sure that the wires are beneath, so rain doesn't get in. Of course, then road crud can get in.
Jim
'95 Kawasaki Concours
Sold my Vulcan
I do LOTS of dumb stuff. Riding is only one of them.
jimkonst is offline
post #4 of 16 (permalink) Old 07-11-2010, 09:59 AM
dirtrack650's Avatar
I suggest you rubber mount the plate or the r/r to the plate. Vibration is a killer too.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #5 of 16 (permalink) Old 07-11-2010, 12:11 PM
Chavisimo's Avatar
I have my plug upward and put 3 coats of liquid electrical tape on it to prevent water and other objects getting in there. I did also put dielectric grease with the plug as an extra precaution.
VROC Number: 31246
2003 Kawasaki VN750 SOLD
2006 Honda VTX1800C
Chavisimo is offline
post #6 of 16 (permalink) Old 07-11-2010, 12:39 PM
baldy's Avatar
Dielectric grease is a grease that does not interfere with the electrical current and keeps the plug-ins from coroading. I also spray WD-40 or silicone on all electrical connections after plugging them in to shed water from them.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #7 of 16 (permalink) Old 07-11-2010, 02:16 PM
WD is good stuff. I used it on my vintage dirt bike points to dissipate water.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #8 of 16 (permalink) Old 07-11-2010, 03:43 PM
Actually, dielectric grease DOES interfere with electric current. It's an insulator. It isn't supposed to be used directly on the metal contacts, in fact, it can cause problems if it's not squeezed out when the connectors are mated. Dielectric grease is supposed to be used on the outside of plastic and rubber (non-silicon, DG eats silicon rubber) connections to keep out moisture. Like putting it on the inside of a spark plug boot..... it doesn't go on the metal part, just between the boot and ceramic.
dariv is offline
post #9 of 16 (permalink) Old 07-11-2010, 07:26 PM
baldy's Avatar
I stand corrected. Thanks dariv
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
post #10 of 16 (permalink) Old 07-11-2010, 10:31 PM Thread Starter
'03 VN750 "Rosie"
bstew7890's Avatar
I like the idea of the liquid electrical tape. I think I will get some of that and spray some WD40 on the plug as well, after it's plugged in. Thanks for the tips everbody!
'03 VN750 "Rosie"
Lubed Splines
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
