stator low voltage - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 35 (permalink) Old 07-08-2010, 09:37 PM Thread Starter
stator low voltage
Replaced the r/r and no go......
The stator has 0.7 ohms leg to leg and no continuity to ground.
But checking the voltage and I get 5vac at idle and 20vac at 5k rpm.
NOW WHAT?!?!
dariv is offline
post #2 of 35 (permalink) Old 07-08-2010, 10:03 PM
sounds like replace stator!
post #3 of 35 (permalink) Old 07-08-2010, 11:04 PM
Crobins365's Avatar
Sorry to hear that, but I agree with Denny: Sounds like a fabulous engine pull is in your future! It's really not such an ordeal, though, and besides, you've got all kinds of support here to tackle the job. Fire away with questions - we'll all have you back up and running in no time!
C
Crobins365 is offline
post #4 of 35 (permalink) Old 07-08-2010, 11:27 PM
engine pull/tilt, and new stator.. time to give tim a shout.
post #5 of 35 (permalink) Old 07-09-2010, 12:08 AM Thread Starter
humm......looks like the biggest part of the project is getting the case to clear the frame.
Why not just modify the frame so that part of it is removable?
dariv is offline
post #6 of 35 (permalink) Old 07-09-2010, 12:11 AM Thread Starter
how much time is needed to do a stator replacement ?
and.... what is the "best" stator to use?
dariv is offline
post #7 of 35 (permalink) Old 07-09-2010, 12:24 AM
IMBoring25's Avatar
Some people have modified the frame rail, but I haven't seen any approaches that I believed would restore the structural integrity of the frame.
IMBoring25 is offline
post #8 of 35 (permalink) Old 07-09-2010, 12:29 AM Thread Starter
An experienced welder could put it back good as new.... of course getting a good weld with the engine in place would be a trick.
dariv is offline
post #9 of 35 (permalink) Old 07-09-2010, 10:14 AM
Warlord247's Avatar
X3 on the stator.
The engine tilt sin't so bad, as long as you take your time and have the tools. I did mine in about 2 hours (but I am a full time auto mechanic).
Make sure your stator is made in the US or Canada. You can find them on ebay for about $100. you will also need the gasket,and would recomend soldering the 3 leads instead of crimping them. Gives you a better connection that won't be a suseptable to corrosion.
We're here for support!!
"The Mistress".
1985 VN700A1
MODS:
New stator
My version of the Marbleing
New paint and trim
New oversized front tire
Degoated
Iridium Plugs
New grip and lever covers
New(er) Ignition switch
Waiting on:
A good ride
As always:
Wanting attention at all times.
Why should I act my age, I am an ADULT!!!!!!
Warlord247 is offline
post #10 of 35 (permalink) Old 07-09-2010, 11:11 AM
For where to get a stator... Tim Parrot of TPE has the best deal... 69 bucks... he custom winds your stator, guarnateed not to fail. [email protected]
