I need a new regulator!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 07-04-2010, 06:50 PM Thread Starter
OK....so it seems like I can never just take the bike for a ride without something else dying...... today it was the r/r.
The connector on the r/r was somewhat melted and ugly. I pulled the r/r and performed the resistance test from the manual and it failed...open where it should have some resistance.
So....the question is where do you think I should buy one from (I would rather buy new from a website rather than ebay) and what model do you suggest? I assume there is a better alternative to the stock unit. I'm not scared to do a little soldering/wiring mods if needed....
Please advise!
dariv is offline
post #2 of 8 (permalink) Old 07-04-2010, 07:05 PM
Please advise!
read this thread it is about ,what seems to be a lit better regulator than ours is stock.you need to rewire the headlight ,though it will charge at lower rpm's and run cooler also according to a couple of the guys on here that have swapped for the newer style r/r. https://www.vn750.com/forum/showthread.php?t=14928
post #3 of 8 (permalink) Old 07-04-2010, 09:22 PM
Crobins365's Avatar
Dariv, I have a new Rick's R/R for $75, shipped. In looking at your signature line, it doesn't appear that you've relocated yours yet? Probably the first order of business, regardless of whether you go with the type Denny mentions or something a little closer to stock.
Shoot me a pm if you're interested.
C
Crobins365 is offline
post #4 of 8 (permalink) Old 07-05-2010, 12:53 AM
Good point, it definitely gets it away from other heat sources and the bottom of the battery, a sure fire place for corrosion if you do not keep a close eye on it.
post #5 of 8 (permalink) Old 07-05-2010, 12:57 AM Thread Starter
I have no goat belly, so there is plenty of air flow around the r/r.....
dariv is offline
post #6 of 8 (permalink) Old 07-05-2010, 11:21 AM
skalding's Avatar
I did the conversion as mentioned in the thread and the charge seems very steady. I also have a spare Ricks RR if anyone is looking for one.
Scheherazade
'86 VN750
MF Battery, Iridium Plugs, RR relocated, Voltmeter, 170/80/15 Kenda Kruz rear tire, DIY Samsonite hard bags, DIY shaved seat with Beaded seat pad ('cause that's how I roll) and the dreaded STATOR CHANGE.
Shining Black Bess '86 VN750, retired for parts after a fried stator and being knocked (kee-runch) in her parking spot.
skalding is offline
post #7 of 8 (permalink) Old 07-13-2010, 09:39 AM
johnm's Avatar
PM sent.
1989 VN750
VROC#31798
I'm bad with names. May I just call you dumb?
johnm is offline
post #8 of 8 (permalink) Old 07-13-2010, 11:06 AM
baldy's Avatar
Yeah the connection gets a lot of heat and if the battery leaks the acid runs down onto the r/r connections. With these factors corosion sets in and if not checked it will toast the r/r and connector. Mine was so bad that I had to get another wiring harness that had a good r/r connector and replaced it. If you do this put the dielectric grease to it and any time you have the side cover off take a look at it. Plus if you have the belly off and get a MF battery will help too.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
