Tach jumping with power loss - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 07-01-2010, 07:31 PM Thread Starter
I'm on my way home today and the bike intermittently stutters around 3000~4000 RPM. I figure it's probably the stupid carb vent hose again, but then I notice that the tach jumps up about 500 RPM and back down when the bike stutters. Any thoughts on this one?
BTW- my kickstand switch has never worked, don't know why that would cause a problem cruising but just thought I should throw it out there. Also my ignition switch sometimes needs a little jiggle with the key when you turn it to the on position....the lights come on, but the neutral indicator doesn't light and the bike wont turn over till you wiggle the key a little.
dariv is offline
post #2 of 13 (permalink) Old 07-01-2010, 09:00 PM
Send a message via AIM to MikeW0311 Send a message via Yahoo to MikeW0311
I'm having a similar problem, been posting at:
https://www.vn750.com/forum/showthrea...t=13849&page=2
Still looking for a solution?????
MikeW0311 is offline
post #3 of 13 (permalink) Old 07-01-2010, 09:44 PM
Clean the key switch first and go from there.
post #4 of 13 (permalink) Old 07-01-2010, 10:20 PM Thread Starter
I now believe the issue with the tach is unrelated to the stutter. Sometimes the tach jumps with out any loss of power......
I ran the bike at highway speed while playing with the carb vent hose and still believe my problem may be there. That tube is damn picky.
dariv is offline
post #5 of 13 (permalink) Old 07-01-2010, 10:39 PM
If you are shaven and have a black box under your fuel tank, connect the carb vent hose to it. Make sure that the hose is not bent or cincked. That is where I connected mine.
post #6 of 13 (permalink) Old 07-01-2010, 10:53 PM Thread Starter
What is that "black box" for, anyway?
dariv is offline
post #7 of 13 (permalink) Old 07-01-2010, 11:02 PM
I have been told here that it is for connecting this very hose. There is no connection into the fuel tank from it.
post #8 of 13 (permalink) Old 07-01-2010, 11:44 PM Thread Starter
This begs the question, then why is it in the right ear?
dariv is offline
post #9 of 13 (permalink) Old 07-02-2010, 12:08 AM
I don't have that answer.
post #10 of 13 (permalink) Old 07-02-2010, 01:28 AM
w.waters1's Avatar
Thumbs up Had that problem
I had the same problem but found the problem was the ground wire off of the battery. Might want to check that out. Mine did the same thing till it died. I found that the negative came off. Once I got it back on and tightened up I was good to go. No problems since. Try that or check the rest of the ground wires.
w.waters1 is offline
