Starting issues - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 06-25-2010, 09:41 PM Thread Starter
Bronson's Avatar
Starting issues
Hi:
The last few times I have refueled, I have had problems starting the bike. I get good cranking from the starter, and have ridden far enough to have good charge on the battery. I will get backfire if I give it throttle when trying to start, so I think there is not enough spark.
Since I could not restart, I jumped the battery and the bike starts immediately without hesitation, so I think that means there is not enough juice to crank the starter and get hot spark. Even so, when I rode home, about 5 min. ride time, and shut down, I had no trouble restarting! The battery must be getting charge from the stator and regulator. I have a yuasa battery that is only 2 months old. This only seems to happen when I'm adding fuel.
I have made some capped cables so I can put a battery charger/tender on without taking off the seat to keep the battery at max as much as possible, and I'm ordering iridium plugs from JC Whitney today to see if that helps. They were $7.88 and have free shipping today if you use the promo code "free4me". I'll post again later to tell if these remedies had the desired effect. If there are any other ideas to address this type of problem I will be happy to investigate them too.
2005 VN 750
Plexistar windshield
.040 pilot jets.
Splines lubed 1955 mi.
Iridium plugs
Reset pickup coil gaps.
Metzeler ME=880s
Shindengen MOSFET RR
V & H Cruzers
Degoated
Speed bleeders
MCCTs.
Bronson is offline
post #2 of 3 (permalink) Old 06-26-2010, 01:34 AM
Common problem with the VN.
Set the air gap on the pick up's on your stator. There is a thread in this site to do that. Not to hard to do.
Try also not to open the throttle when starting a hot motor.
By setting the gap closer, you will get rid of the backfire although I kinda miss it to scare the Hell out of kids!!!
honest Al is offline
post #3 of 3 (permalink) Old 06-26-2010, 01:02 PM Thread Starter
Bronson's Avatar
Thanks Al, I'll check that too. How do you like the PI?
2005 VN 750
.040 pilot jets.
Iridium plugs
Metzeler ME=880s
V & H Cruzers
Degoated
Speed bleeders
MCCTs.
Bronson is offline
