Left Blinkers now work, Right side...... not so much - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 06-23-2010, 05:24 PM Thread Starter
CANNiBAL_EyEZ's Avatar
I realized my fron turn signals are after market signals so I had to play around for a while. Both left work now! The right side however won't work at all. Also, there's no turn signal clicking sound or flashing on the panel (the left blinker and neutral lights work on the panel so I'm sure thats good) . Could the flasher unit be bad? Anyone have any ideas of what i can check or start messing around with?
THEY CALL USE WALKING CORPSES
UNHOLY LIVING DEAD
CANNiBAL_EyEZ is offline
post #2 of 3 (permalink) Old 06-23-2010, 07:38 PM
'85 Bobber
drodeo17's Avatar
If it is the flasher you can get a replacement at Autozone in their "help" aisle. Positive most other parts houses have the same.
drodeo17 is offline
post #3 of 3 (permalink) Old 06-23-2010, 10:25 PM
If the lights are flashing on the left side, I believe the flasher unit is ok. There must be a problem with the wiring, sockets or bulbs on the right side.
It has been 2 years since I have been able to ride, and I don`t remember 100% if the flasher clicked or not, but I don`t think mine did.
The only suggestion I can make is use a test light starting at the socket, and work your way back through every connector and solder joint in that circuit until you find a live wire.
