CDI specs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 06-22-2010, 02:27 PM Thread Starter
CDI specs
Hi, i just picked up a 92 and cant get it to start; even with starting fluid, compression is good. It has spark but when i check ohms on the CDI several specs are way off. Also on the flywheel, wich timing mark should line up with the pointer (going off front cyl) the first line, the sideways "T" or the "F"? right now its a few degrees before the first line.
thanks
rdzombie is offline
post #2 of 8 (permalink) Old 06-22-2010, 05:52 PM
Crobins365's Avatar
Timing mark for the front cyl is the line in front of the "T". When you say it won't start, are you getting anything at all? A click from the starter solenoid? Dash lights? Any attempt by the starter to turn over?
C
Crobins365 is offline
post #3 of 8 (permalink) Old 06-23-2010, 12:56 AM
The Professor
lance328's Avatar
thanks
What kind and how old is the battery, with a weak battery it will turn over but won't start.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 8 (permalink) Old 06-23-2010, 01:15 AM
MANIC MECHANIC
vulcanjoe's Avatar
thanks
If it has not been tampered with the timing should be ok. Second thing the bikes are not CDI They are TCI (Transistor Controlled Ignition) It basically works like inductive pickup except instead of being controlled directly by the pickups. The pickups control transistors that feed ground to the coils.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #5 of 8 (permalink) Old 06-23-2010, 01:21 AM
MANIC MECHANIC
vulcanjoe's Avatar
Ron is right just because you have spark doesen't mean it is strong enough to ignite the air fuel mixture. Check voltage at the coils while cranking.
34k so far
coastered
spline lube
TPE stator
post #6 of 8 (permalink) Old 06-23-2010, 01:56 AM
The Professor
lance328's Avatar
Actualy it is CDI "Capacitive Discharge Ignition" it uses a capacitor to emit a quick burst of High Voltage current, the ignition coil is charged by the capacitor. Yes!! The CDI module is transitor controlled.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 8 (permalink) Old 06-23-2010, 04:43 AM
Actualy it is CDI "Capacitive Discharge Ignition" it uses a capacitor to emit a quick burst of High Voltage current, the ignition coil is the capacitor. Yes!! The CDI module is transitor controlled.
Are you serious? As vulcanjoe said, it is not CDI. A CDI uses low resistance coils (less than 1ohm) and the other end of the primary winding is connected to ground.
pappa is offline
post #8 of 8 (permalink) Old 06-23-2010, 08:04 AM
The Professor
lance328's Avatar
Not in the least, messin with Joe.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
