moving the r/r - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 06-21-2010, 11:21 AM Thread Starter
moving the r/r
so when i start getting deeper into my chargeing system next month and replace my stator. i was considering moving my r/r. i bought one off a 1500 or 1100 used that worked because it dosnt have as much issues with over heating from what i heard. but i was wondering. when i move it can i9 go to like home depot or something to find a small bracket that works well or so i need to make one up my self? what are some of they things you guys have done?
ramcharger is offline
post #2 of 6 (permalink) Old 06-21-2010, 11:50 AM
dirtrack650's Avatar
Thumbs up Yes and Yes
It is that easy and cheap. Here's a bracket from Home Depot that had two holes already drilled in it, I used rubber washers on both sides to help isolate from vibrations, and you're done.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #3 of 6 (permalink) Old 06-21-2010, 11:51 AM
Aluminun diamond plate would work. This is what I did.
post #4 of 6 (permalink) Old 06-21-2010, 07:32 PM
Here is a link to fergy`s r/r relocation bracket made with a couple of pieces of strap steel, a 1 1/8" U-clamp, 2 bolts and a short piece of 3/8 fuel line.
http://pages.tstar.net/~fergy/writeu..._relocate.html
If you are not going to remove the original r/r, ignore the first part.
The last picture shows the final results.
post #5 of 6 (permalink) Old 06-22-2010, 12:14 AM
Remember to add dielectric grease to the connection block. Moving it to this location increases road debris, water and all sorts of crap if you ride in bad weather.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #6 of 6 (permalink) Old 06-22-2010, 01:54 AM
KIMMERLING's Avatar
good point on the grease. I lubed mine up till it oozed out!
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
