Volt meter for our VN's??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 06-17-2010, 07:11 PM Thread Starter
dirtrack650's Avatar
Thumbs up Volt meter for our VN's???
LED volt meter
I think I'm going to order one.
I bet the current draw is so low it can be directly wired to the battery w/o any worries of drain.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #2 of 11 (permalink) Old 06-17-2010, 07:19 PM
Looks good DT.
post #3 of 11 (permalink) Old 06-18-2010, 01:26 AM
HAWK
Ccspinner's Avatar
I would worry about water, is it sealed?
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #4 of 11 (permalink) Old 06-18-2010, 01:38 AM
MANIC MECHANIC
vulcanjoe's Avatar
if you read the pdf instructions it is powered by 5v I dont know if this would work
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #5 of 11 (permalink) Old 06-18-2010, 10:00 AM Thread Starter
5V? yes I saw that. It would be easy to wire in.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #6 of 11 (permalink) Old 06-18-2010, 10:01 AM
Cruisin' through my 50's
newOldUser's Avatar
DT,
Please follow up with a report on this unit if you buy it. I'd be interested to know how well it works and how you attached it.
Manual says 5v but ebay and picture on circuit board on ebay seem to indicate 12v.
newOldUser is offline
post #7 of 11 (permalink) Old 06-18-2010, 11:31 AM
Senior Lurker
Sloppyburpfest's Avatar
Looks a bit big for my tastes. Will the color of the LEDs match anything on your bike or will it stand out like a sore thumb?
-Sloppy
My Flickr Gallery < Link >
Küryakyn LED battery monitor
R.I.P. Lance328
Sloppyburpfest is offline
post #8 of 11 (permalink) Old 06-18-2010, 11:33 AM
ryn
5 volt powers it, then the 12 v circuit sends the signal. I used a dismantled usb cigarette plug style chargers for power (usb charges at 5v) in a similar project. The led is trying to compete with the north star or something though, it is bright!
ryn is offline
post #9 of 11 (permalink) Old 06-18-2010, 12:17 PM
Columbus, Ohio
jimkonst's Avatar
Originally Posted by dirtrack650 View Post
LED volt meter
DT
It's just as easy to do it right. Find a wire in the light bucket that comes on with the ignition.
Wiring it directly to the battery because it is a low drain is like allowing a small cut to bleed. One day your battery will be old and your wiring will be ineffiecient. Then that small drain will bite you in the ass. Also, anything wired to the battery post tends to loosen the wires.
I recently wired the kuryakin meter which is similar in principal to yours. And It didn't take a three foot length of wire so I could keep it all out of the weather. At firt I just jammed the wire into the light bulb socket, but after I thought about it I wired it properly. Crimps and shrink tube.
Jim
'95 Kawasaki Concours
Sold my Vulcan
I do LOTS of dumb stuff. Riding is only one of them.
jimkonst is offline
post #10 of 11 (permalink) Old 06-18-2010, 06:10 PM Thread Starter
Exclamation I thought of that too!
I have a Sunpro meter wired in the right way now - on and off with the ignition. I was thinking how nice it would be to be able to monitor the voltage w/o the key. I do attach a battery maintainer when I don't plan on riding for a few days so I'm good with that.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
