Rear LED turn signal swap out - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 06-17-2010, 01:34 PM Thread Starter
clock152's Avatar
I have looked thru most of the threads on changing turn signals out for LED turn signals.. and I cant find what I am looking for..
I picked up a set of smaller 18 bulb LED turn signals and want to MOD them on the rear of the bike to replace my wornout/broken turn signals... my question is.. will they use the same wires as the old trun signals?.. Will I have to add anything to the electrical system to make them work?.. dont want to plug them in and fry them or anything on the bike.
clock152 is offline
post #2 of 21 (permalink) Old 06-17-2010, 01:45 PM
flitecontrol's Avatar
Yes.
You will need to swap out the stock thermal flasher for an electronic one. The LEDs don't draw enough current to activate a thermal flasher.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is online now
post #3 of 21 (permalink) Old 06-17-2010, 02:02 PM Thread Starter
clock152's Avatar
cool.. will that still run the front flashers.. they will still be the bulb type (not changing those out...adding a light bar that I picked up off of Ebay)
clock152 is offline
post #4 of 21 (permalink) Old 06-17-2010, 02:58 PM Thread Starter
clock152's Avatar
clock152 is offline
post #5 of 21 (permalink) Old 06-17-2010, 03:22 PM
93VN750's Avatar
Yes and change your brake/tail light too while you are at it.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #6 of 21 (permalink) Old 06-17-2010, 03:30 PM
MANIC MECHANIC
vulcanjoe's Avatar
I don't see why not but it would be faster to go to your local auto parts store and get one.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #7 of 21 (permalink) Old 06-17-2010, 03:41 PM Thread Starter
clock152's Avatar
Great thanks all.. and yes I think I will change the tail light too.
clock152 is offline
post #8 of 21 (permalink) Old 06-17-2010, 03:49 PM
dirtrack650's Avatar
"will they use the same wires as the old trun signals?"
YES
"Will I have to add anything to the electrical system to make them work?"
NO. If the LED's are the 1156 style bulb or they are designed as blinkers, you should not have to change anything. BTW you can't mix filament bulbs and LED's in the same circuit and use an electronic flasher - read the flasher instructions before you buy.
FYI: 1156 and 1157 style LED lamps are coming down in price, getting brighter, and require NO mods to make them work in the stock lamp housing.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #9 of 21 (permalink) Old 06-17-2010, 04:01 PM Thread Starter
clock152's Avatar
so your saying all LEDs for front and rear turn signals or all bulb type.. cant have LED's in the rear and bulbs in the front?... bummer..... but hey I paid next to nothing for these LED turn signals.. and I have several bulb type signals that I can try.. was going for a better look on the Vulcan butt.
clock152 is offline
post #10 of 21 (permalink) Old 06-17-2010, 04:02 PM
If you are leaving the stock incandescent bulbs in the front signal stocks, you DO NOT need an electronic flasher.
The stock flasher will work with one filament bulb and one LED cluster just fine.
Only if you change out all 4 signals for LED lights do you need an electronic flasher.
