bad R/R? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 06-14-2010, 12:39 PM Thread Starter
bad R/R?
After a full battery charge I can get her started voltage at idle is 13.8 I rev the engin voltage goes down to 13.6~13.2 range I let off throttle and voltage goes up. Does that make my R/R bad or miss wired? the wire harness on R/R was melted and showed lots of signs of shorting arcs. I am about to order a new R/R, it has been relocated but it was done by previous owner so I don/t know if it was done right or not. But that is the path I am going down. Any advice would be great, thanks to all
matty is offline
post #2 of 5 (permalink) Old 06-14-2010, 12:43 PM Thread Starter
Also I gave the battery a full charge yesterday and she starts up great but only runs as long as the charge in battery is there. then dies and battery level is 12.6 and droping
matty is offline
post #3 of 5 (permalink) Old 06-14-2010, 12:53 PM
Chavisimo's Avatar
Look in the verses for stator and R/R tests. Test both to be on the safe side.
VROC Number: 31246
2003 Kawasaki VN750 SOLD
2006 Honda VTX1800C
Chavisimo is offline
post #4 of 5 (permalink) Old 06-14-2010, 02:54 PM
baldy's Avatar
Sounds like your stator is toast but yeah check them both. Take the left side cover off and in front of the battery box there is 3 yellow wires. Check those for corrosion or broke off. Unplug them one at a time to check them. I think if you mess up the order it will do something. (Damn CRS!!) haha
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #5 of 5 (permalink) Old 06-14-2010, 03:22 PM
flitecontrol's Avatar
The three yellow wires can be plugged into any of the other yellow leads. It doesn't matter.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
