remove rear directionals - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 06-10-2010, 12:52 PM Thread Starter
I'm putting on a set of hard bags and having a difficult time removing the stock rear directionals. I removed the single screw and can't figure out how to remove the harness. Any suggestions
prusakmi is offline
post #2 of 4 (permalink) Old 06-10-2010, 12:57 PM
GIMPYRDR's Avatar
Gently twist the stalks one direction or the other (don't remember which) this will unlock them to take them out of the holes. Then under the seat between the frame and fender are the wires with bullet connectors. You may have to loosen the fender up a bit to get the wiring out. Also, find a post by another member named OldHossCanada. In his signature line is a link for a down loadable manual.
2005 Vulcan 750
Black and Silver
Saddlebags
OEM Hghwy Bars
O-ring Footpegs
OEM Luggage Rack
V&H Exhaust System
TOC ACCT Rebuild
Die Hard Gold AGM MFB
Spline Lube every tire change
VN750 #4393
VROC #31065
TexasVROC
GIMPYRDR is offline
post #3 of 4 (permalink) Old 06-10-2010, 01:07 PM Thread Starter
thanks
prusakmi is offline
post #4 of 4 (permalink) Old 06-10-2010, 02:33 PM Thread Starter
thank you
prusakmi is offline
