voltage question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 06-06-2010, 07:52 PM Thread Starter
Question voltage question
with bike running at idle how many volt should be at battery leads. and at lets say 3000rpm
shadowman is offline
post #2 of 7 (permalink) Old 06-06-2010, 09:57 PM
The Professor
lance328's Avatar
Around 13.2- 13.9v
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 7 (permalink) Old 06-07-2010, 01:01 PM
My bike seems to drop significantly when the fan is running at idle. I tested it and it appears that the voltage is barely over 12.8 when I rev the engine over 3k. It is even less when at idle. Is this normal?
Krup327
Denver, CO
'01 with 21,000 mi
TOC ACCTs
Iridium Plugs
LED tail light
EBC Kevlar Clutch
Tim Parrott Stator
Kuryakyn LED volt meter
Batteries Plus AGM Battery
Metzler ME 880s front and rear
Willie and Max Universal soft bags
Shindengen MOSFET FH012AA Regulator/Rectifier (relocated)
krup327 is offline
post #4 of 7 (permalink) Old 06-07-2010, 06:11 PM
Calif Rider
weh44att's Avatar
Krup327 at a stop,with the brake on and the fan running there is a big drop in voltage. Even with just the fan running it pulls a lot of volts. But it is not really normal for the volts to drop more when you increase the RPM's to 3000. Your reading should go up when you REV up the engine. Mine at a stop and the fan running the volts can be from 12.6 to maybe 13, at times even lower with the brake on.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #5 of 7 (permalink) Old 06-09-2010, 01:09 AM
My voltage does increase when revved and I am getting similar readings to yours. It looks like it is normal for the fan to put a big draw on the electrical system. Thanks for sharing your readings.
On a related note, I just replaced my tail light bulbs with an LED board from Clear Alternatives and I am very happy with it. It frees up some current at idle and is a LOT brighter than stock.
krup327 is offline
post #6 of 7 (permalink) Old 06-09-2010, 05:21 PM Thread Starter
my bike reads around 12.8 at idle and around 13.5 to 13.8 at 3000rpm. so thats abt normal?
post #7 of 7 (permalink) Old 06-09-2010, 06:24 PM
ExNewbie..Still Learnin'!
rsawyer's Avatar
No problems there, good readings.
'89 Vulcan 750
VROC# 30232
HID Headlamp Conversion
V&H Cruzers (great sound)
Kaw V-Force Windshield
Kaw Rear Luggage Rack
Kaw Engine Guard
VN750.COM Grill Cover
W&M Black Magic Saddlebags
Diehard M/F Battery
R/R Replaced/Relocated
Stator Replaced
Voltmeter Installed
Splines Lubed
Metzler 880 Marathons
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
Fuel Tank Derusted/Lined/Sealed
NGK Iridium Plugs
rsawyer is offline
