Headlight not working after installing SHINDENGEN MOSFET FH012AA REGULATOR/RECTIFIER - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 06-02-2010, 04:06 PM Thread Starter
Hi all,
I have been a long time reader, but this is my first post. Thanks to all of you for sharing your knowledge.
I recently installed a SHINDENGEN MOSFET FH012AA REGULATOR/RECTIFIER by running the 3 yellow stator leads directly to the r/r and then outputting directly to the battery terminals.
I bought the r/r from the roadstercycle website and followed the directions in hooking it up.
The good news is the charging system seems to be working well. The bad news is headlight does not work now (all other lights work ok tho).
What do I need to do to get the headlight working properly again?
Krup327
krup327 is offline
post #2 of 22 (permalink) Old 06-02-2010, 04:12 PM
Send a message via Yahoo to luigit
headlight is controlled by a relay which is connected to one of the legs of the stator. you may need to rewire the headlight to get direct power (the blue lead in the steering head i believe)
slim
does this sound right?
luigit is offline
post #3 of 22 (permalink) Old 06-02-2010, 04:27 PM Thread Starter
I was thinking I could just splice into one of the stator leads and run it back to the yellow wire going into the junction box. Would this harm anything?
Krup327
krup327 is offline
post #4 of 22 (permalink) Old 06-02-2010, 07:12 PM
skalding's Avatar
I don't think you should plug a wire directly from the stator into anything other than the RR.
Scheherazade
'86 VN750
MF Battery, Iridium Plugs, RR relocated, Voltmeter, 170/80/15 Kenda Kruz rear tire, DIY Samsonite hard bags, DIY shaved seat with Beaded seat pad ('cause that's how I roll) and the dreaded STATOR CHANGE.
Shining Black Bess '86 VN750, retired for parts after a fried stator and being knocked (kee-runch) in her parking spot.
skalding is offline
post #5 of 22 (permalink) Old 06-02-2010, 08:32 PM
X2 to skalding. The stator wire is outputting anywhere from 20 to 50 volts AC, if I remember correctly.
post #6 of 22 (permalink) Old 06-02-2010, 10:18 PM
baldy's Avatar
Have you checked the headlight fuse?
I had a problem with the headlight and it was internal of the HB. So I found the headlight wire going into the HB and ran it into the auxiliary lighting plug under the right side cover along with a toggle switch where it is constant power until I could get a new HB.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #7 of 22 (permalink) Old 06-02-2010, 10:58 PM
MANIC MECHANIC
vulcanjoe's Avatar
i had the same problem when i installed mine so i wired it up like the factory with the stator lead to the jb then the r/r would not charge what i did was take the brown sense wire from the old r/r connector and solder it to the yellow wire from the small plug on the j/b. the headlight is on all the time now there is no longer a delay to turn on the headlight. hope this helps
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #8 of 22 (permalink) Old 06-02-2010, 11:21 PM
Krup327
this is absolutely correct, there is a relay that is inside of the JB that is switched on by one leg of the stator ,when the engine is cranked over,the yellow wire on the JB is connected in the factory harness to one of the stator yellow wires,I am going to presume you ran the stator wires directly to the R/R bypassing the yellow wires in the harness,just do what vulcanjoe did ,or run a wire from either stator lead to the yellow wire on the JB if you want the headlight to come on automagically.you almost have this whipped.
post #9 of 22 (permalink) Old 06-02-2010, 11:43 PM
MANIC MECHANIC
vulcanjoe's Avatar
problem is if you run a lead from the stator for some reason the r/r will not reach over 12.7v as soon as i disconnected it i went right back to 14.5v
34k so far
coastered
spline lube
TPE stator
post #10 of 22 (permalink) Old 06-03-2010, 12:18 AM
weird, did you leave it connected to the r/r and jump to the yellow wire on the JBor disconnect one and ?and hook it to the JB
