Nuetral light not working - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 05-30-2010, 08:26 PM Thread Starter
baldy's Avatar
This isn't a big issue where I know to hold the brake to check if it is neutral or not when running but....when I bought my 01' the neutral light only came on if the handlebars were turned to the left. All the other lights work fine. Now it doesn't come on at all. The plug-in under the bike is good (had that issue with my 93). Also one time I had to park it over night in a parking lot and I locked the handlebars to the left and the battery went flat. It was an older battery but it never went flat over night. Where shoud I check next?
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #2 of 3 (permalink) Old 05-31-2010, 04:35 PM
1986vn750's Avatar
i was having some similar problems with my 86 vn750. when i turned the handlebars to full left. some things would quit working. the wiring harness only has so much slack in it. i removed the tank, and seat. and sure enough when i turned to full left that harness became tight. and those plugs were not making good contact. so i freed up some slack and no more electrical problems. I dont really know how to diagnose your issue. but maybe the N light bulb housing is corroded? rain maybe?
1986 Vn750
18,800 miles, and counting
Bone Stock
New cam chain tentioners
all fluids changed
Spline Lube
windshield
Engine Guard
B-stone S11 RWL-stock sizes
*wanted*
New grips
2001 Vn750
13,100 miles, and counting
spline lube
Bridgestone S11 100/90
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
1986vn750 is offline
post #3 of 3 (permalink) Old 05-31-2010, 11:28 PM Thread Starter
baldy's Avatar
It is just the nuetral light but that is something I will check with the harness and I will be pulling the unit apart to check the light and socket for corosion. The bike was left out in the weather a LOT before I got it, now it is under cover every night.
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
