R/R relo technical help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 05-27-2010, 09:03 PM Thread Starter
After a hard 12K miles in a year (daily commuter), my 2004 VN750's regulator/rectifier and stator fried recently (i hadn't replaced or relocated the R/R, should have heeded the warnings here).
I'm planning to relocate the R/R to near the left rear footpeg and I want to make my own bracket. My bike's sitting in the shop waiting for parts (Electrosport, both stator and R/R), so I can't measure the distance between the mounting holes in the R/R.
Can someone tell me the measurement between the bolt holes, on center? Pics of the Electrosport show slots sted of holes, so I have some wiggle room, but wanted to get the exact measurement.
Thanks,
DaveW (Tucson)
davew is offline
post #2 of 16 (permalink) Old 05-27-2010, 09:58 PM
flitecontrol's Avatar
No need to double post (answered this in the Introduction section), but this would have been the best place to post.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 16 (permalink) Old 05-29-2010, 11:43 PM
CBH
CBH's Avatar
Relocating the R/R is something that is needed for a warmer climate? I live in Northern Ontario, its gets above 85 degrees sometimes, not on a regular basis. Is this a must for all of us? My bike currently has 35,000 miles on it and it hasn't been changed. Thanks.
1985 750 Vulcan-Red
36,875 miles
New timing chain
New choke cable
Clean front rim
new throttle pull back cable
new spark plugs
New Bridgestone on the back
New Fluids all around
SeaFoam in the tank
CBH is offline
post #4 of 16 (permalink) Old 05-29-2010, 11:51 PM
As I understand the rationale, it is to get the r/r away from the heat produced by the goat's belly and out in the open where it can cool more readily. If your bike has had the goat's belly removed, it may not help to relocate the r/r.
"Black Beauty"
Old Blue
post #5 of 16 (permalink) Old 05-30-2010, 09:28 AM
baldy's Avatar
I have also heard that if the stator goes first and not noticed or thinking it is just the battery and replacing that. Continuing to ride with a fresh battery and stator not working will overload the r/r?
One other reason for relocating though is the battery acid leaking out if you do not have a long enough vent tube or a leaking battery, or just get a MF battery.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #6 of 16 (permalink) Old 05-30-2010, 11:31 AM
The Professor
lance328's Avatar
The battery can't overload the R/R if the stator has fried.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 16 (permalink) Old 05-30-2010, 02:16 PM
baldy's Avatar
Ok cool thanks for setting me strieght lance.
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
post #8 of 16 (permalink) Old 05-30-2010, 04:52 PM
CBH
CBH's Avatar
When installing a volt meter, what does it enable you to do? What are you looking for and whats happens when you find it? If that makes sense.
1985 750 Vulcan-Red
36,875 miles
New timing chain
New choke cable
Clean front rim
new spark plugs
SeaFoam in the tank
CBH is offline
post #9 of 16 (permalink) Old 05-30-2010, 06:06 PM
The Professor
lance328's Avatar
It lets you keep an eye on the battery voltage, so if the voltage drops and keeps dropping you know you have a charging problem when it is actually happening and not when the bike suddenly stops running.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #10 of 16 (permalink) Old 05-30-2010, 06:08 PM
CBH
CBH's Avatar
Ahhh...ok, that makes sense. Thank you
1985 750 Vulcan-Red
36,875 miles
New timing chain
New choke cable
Clean front rim
new spark plugs
SeaFoam in the tank
CBH is offline
Tags
electrical
