Blinker Running Lights - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-25-2010, 11:26 PM Thread Starter
KwisatzHaderach's Avatar
Do the blinkers usually stay on for running lights? I just noticed mine stay on, until I hit the blinker switch. Did a previous owner do a mod to these?
KwisatzHaderach is offline
post #2 of 6 (permalink) Old 05-25-2010, 11:29 PM
MANIC MECHANIC
vulcanjoe's Avatar
the front do the rear do not
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #3 of 6 (permalink) Old 05-26-2010, 12:08 AM Thread Starter
I guess someone must have modded mine. They stay one the same as the fronts. Unfortunately I got a burr up my butt to use the helmet lock today. The older rubber on the blinker on the back cracked from pulling the saddle bag up and down. I hope it does not get a short in it.
post #4 of 6 (permalink) Old 05-26-2010, 09:25 AM
skalding's Avatar
The rubber cracks easily. Sometimes the signal stalks start to sag and get droopy. One solution is to pull apart a blue papermate ballpoint pen (fatter bic ones do not work). It fits the interior hole of the signal mounts perfectly and stiffens them up considerably. You just cut the pen down to size (remove ink first), thread the wires through the pen shaft, and slide the shaft up into the signal. Works like a charm.
Hmm. Given: "shaft, sag, droopy, and stiffen," I'm waiting for a beavis and butthead comment.
Scheherazade
'86 VN750
MF Battery, Iridium Plugs, RR relocated, Voltmeter, 170/80/15 Kenda Kruz rear tire, DIY Samsonite hard bags, DIY shaved seat with Beaded seat pad ('cause that's how I roll) and the dreaded STATOR CHANGE.
Shining Black Bess '86 VN750, retired for parts after a fried stator and being knocked (kee-runch) in her parking spot.
skalding is offline
post #5 of 6 (permalink) Old 05-26-2010, 09:57 AM Thread Starter
Don't forget "rubber cracks easily" lol.
I might let it go for a little while and get the relocation brackets and be done with it all together. Thanks for the pen tip, if I don't do the bracket, then I will definitely do that.
post #6 of 6 (permalink) Old 05-26-2010, 02:44 PM
Columbus, Ohio
jimkonst's Avatar
I was getting excited there until I realized you were talking about bikes.
Jim
'95 Kawasaki Concours
Sold my Vulcan
I do LOTS of dumb stuff. Riding is only one of them.
jimkonst is offline
