Dim Headlight? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 05-25-2010, 12:09 AM Thread Starter
1986vn750's Avatar
Dim Headlight?
My headlight is dimmer than it should be on LOW beam. when i switch to HIGH, it does get brigther, ive checked the bulb and both filaments (sp) are fine. I know my system is charging by hooking up a volt-meter. at idle it is about 12v and around 2k rpm, it bumps up to 14v. All my other lights are bright as day, signals, brake, etc... so.. what would cause the headlight to be dim? i dont feel safe to ride at night cuz i "over-ride" the headlight at about 25 mph!! any input will be much appreciated!
1986 Vn750
18,800 miles, and counting
Bone Stock
New cam chain tentioners
all fluids changed
Spline Lube
windshield
Engine Guard
B-stone S11 RWL-stock sizes
*wanted*
New grips
2001 Vn750
13,100 miles, and counting
spline lube
Bridgestone S11 100/90
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
1986vn750 is offline
post #2 of 10 (permalink) Old 05-25-2010, 12:19 AM
The Professor
lance328's Avatar
It could be a bad switch, hl connector terminal, or a bad RLU. Does the hl warning light come on @ low beam?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 10 (permalink) Old 05-25-2010, 12:21 AM Thread Starter
1986vn750's Avatar
YES! i forgot to mention that.... it seems to be on, and when i move it between high and low, the warning light gets very bright.
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
post #4 of 10 (permalink) Old 05-25-2010, 12:26 AM
The Professor
lance328's Avatar
Check the HL connector terminals they kinda fry after the years and loose continuity. If that's not it check the switch and RLU.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 10 (permalink) Old 05-25-2010, 12:28 AM Thread Starter
1986vn750's Avatar
could you be a littlllleeeeeee more descriptive? im not very exp. on electrical stuff. RLU? how do i test the switch?
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
post #6 of 10 (permalink) Old 05-25-2010, 12:38 AM
The Professor
lance328's Avatar
The RLU is the (reserve lighting unit) if one filament burns out it will automaticly switch to the other filament, they do go bad. Remove the left switch assy and clean the HL switch contacts.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 10 (permalink) Old 05-25-2010, 12:41 AM Thread Starter
1986vn750's Avatar
ok. I'll tinker with that tomorrow. and I'll post back with info. thanks Lance. you da man!
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
post #8 of 10 (permalink) Old 05-25-2010, 04:54 PM Thread Starter
1986vn750's Avatar
I just cleaned the contacts on the HL switch. that is working fine. my headlight warning light is on, but both filaments are good. so does this mean my RLU is bad?
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
post #9 of 10 (permalink) Old 05-25-2010, 10:19 PM
do you have a manual? the manual has tests for every electrical system and part on the bike. If you need the manual,check my link for a free pdf version... be warned its a husge file, but well worth it.
post #10 of 10 (permalink) Old 05-26-2010, 11:46 PM Thread Starter
1986vn750's Avatar
yeah i have it.
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
