yellow stator wires - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 05-24-2010, 10:24 PM Thread Starter
yellow stator wires
Noticed the other day after sitting at idle for 10 min, the three yellow wires from the stator were smoking & hot to touch. Any idea what this indicates? Too close to the exhaust or something much worse?? Bike is an '03 with 900 miles.
newby27 is offline
post #2 of 7 (permalink) Old 05-24-2010, 10:34 PM
phurp's Avatar
my wires burned all the way thru about 9 months ago.(pics in my profile) had to solder in new wire. several people on this site who are smarter then me said it was rusty or oxidized connectors on the stator wires. look for the three plug type connectors on those wires and clean them. there is a procedure for testing your stator in the book and i think its on this site somewhere.
1990 vn-750
metzler 880's
r/r relocated
iridium plugs
ngk plug caps
mf agm battery
ballancer and stator replaced. (Lance328)
Pro Tac Backrest
progressive fork springs
fork seals replaced
2003 kdx 220
frp chain gude
frp skid plate
acerbix hand guards
uni filter
phurp is offline
post #3 of 7 (permalink) Old 05-24-2010, 11:28 PM
the stator test is all over the sight.. i know I have posted a full write up on it several times... even made it prety much dummy proof. as for the reason of the wires in question burning... several things it could be... stator shorted to ground, bad connections, bare wires, stator wire leads shorting to ground at the stator housing, and a bad regulator/rectifier can all lead to the cause of your wire issue. ohh one other thing... a bad ground
post #4 of 7 (permalink) Old 05-25-2010, 02:27 AM
dirtrack650's Avatar
My wires got hot too - cause? corroded connectors. I cleaned and used dielectric grease on them and no problems x7 years. Time to check them again...
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #5 of 7 (permalink) Old 05-25-2010, 05:02 AM
My wires also overheated, on both sides of the bullet connectors. The insulation hardened, and one of the connectors simply broke off. I removed the connectors, and soldered the wires together. I have checked them several times after that, and can find no signs of overheating. My theory is that poor contact at the bullet connectors caused very high resistance, which is what overheated the wires. They were nowhere near any other source of heat. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #6 of 7 (permalink) Old 05-25-2010, 08:09 AM Thread Starter
Thanks for the input, guys. I checked the stator out per Clymers manual- OK. Gonna use some dielectric grease and quit worrying so much!
newby27 is offline
post #7 of 7 (permalink) Old 05-25-2010, 10:10 AM
fergy's Avatar
Yep, more than likely corrosion in the bullet connectors causing resistance. Best thing is to trim back to good wire and solder in/heat shrink new wire and toss the connectors. Also, don't bundle all three wires together, but leave them separated. This will keep them from heating on each other.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
