J/B Problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-22-2010, 11:37 PM Thread Starter
94vn750FL's Avatar
J/B Problem
So......I will try to make this short and sweet. I had the infamous no-charging problem. Pulled the motor, replaced Stator. Replaced and relocated R/R. Both are Ricks Motorsport. I also replaced all of the wiring, bought the entire harness off ebay for like $45. I replaced a bunch of other things but not relevant to this problem. I got it all back together, hit the start switch.......nothing. I test all wiring and it HAS to be the J/B. I wired a starter switch from the battery to the solenoid. It turns over like a champ. But I cannot get it to run. It even backfired once or twice. I have ordered a J/B and i am hoping that once I get it in the bike would turn over. Any other suggestions of what I may be missing? I really want to get the ^&*($%^ bike running ASAP. I ride Full-time and I tore it down 5 weeks ago and keep finding new problems. I've been stuck riding my 250cc and its killing me.
94vn750FL is offline
post #2 of 5 (permalink) Old 05-22-2010, 11:55 PM
The Professor
lance328's Avatar
It may be a problem with one of the safety switches.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 5 (permalink) Old 05-23-2010, 03:31 AM
sounds like the engine lock out switch isn't going to ground...
post #4 of 5 (permalink) Old 05-23-2010, 11:00 AM Thread Starter
94vn750FL's Avatar
I tested the wiring from the Switch all the way through each connector and to the J/B. Then from The Solenoid to the J/B. All Circuits were good. I plugged everything back in and was not getting 12 volts to the solenoid. The only link in the circuit that i did not test was the J/B. I am just trying to avoid putting it back together and finding that there is something else wrong. The only problem with the bike when I tore it down was the stator. Now I keep finding others. I really thought that when I bypassed the starter circuit and turned the bike over, it should have started. I am assuming that the wires for the ignitor that run through the J/B are the problem right now. But if I put the J/B on and find that something else is wrong, i am going to throw this POS in a F9&*&ng Lake.
post #5 of 5 (permalink) Old 05-23-2010, 12:53 PM
the JB sends a ground to the Ignition Control Box via a black/white wire on pin number 14. try jumping pin 14 to ground...if that works, move the jumper wire to pins 12, 15,and 16 one at a time... that will tell you if you have a bad diode or a bad safety switch...
