1989 ninja 600r - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 05-19-2010, 11:48 AM Thread Starter
1989 ninja 600r
Hey guys,
I am new a this site so any help would be great.
My problem is a 1989 ninja 600. Well i got it out for the season charged the battery and it crank over for for a bit but no start. Put new plugs in it and now when a turn the key on nothing no lights nothing. battery is good 12.8V if i jump selenoid starter works but there's no power to the dash. Any ideas?
has any body had this problem?
tountzios is offline
post #2 of 9 (permalink) Old 05-19-2010, 12:13 PM
flitecontrol's Avatar
We aren't experts on your bike, but electrical problems are fairly universal. How old is your battery? A fully charged battery should register at least 13 volts. You can try jumping it from a car battery with the car engine not running. If it cranks, the problem probably lies with your battery.
I recently had a battery go bad and it exhibited the symptoms you describe. It had full voltage but zero amps, so I would suggest you check the amps on the battery. If that doesn't get you in business, check your ground and other electrical connections. Clean them with contact cleaner, apply dielectric grease, reassemble, and make sure the connections are tight. Good luck.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 9 (permalink) Old 05-19-2010, 12:25 PM Thread Starter
thank you for your suggestions however i have no ignition lights dash board is dead.
i have check all wires coming out of JB and all are live.
post #4 of 9 (permalink) Old 05-19-2010, 03:05 PM
Check the ignition switch. It should have at least one wire at 12V always and more wires at 12V with ignition on.
pappa is offline
post #5 of 9 (permalink) Old 05-19-2010, 07:03 PM
I had a 1991 zx600 that had a blown main fuse. Not too sure how close the wiring would be but check to see if there is a fuse at the solenoid, on mine you just unpluged the solenoid and the main fuse was right there.
cdaddy is offline
post #6 of 9 (permalink) Old 05-20-2010, 07:14 AM Thread Starter
Ok
Three wires coming out of solenoid one goes to JB and the other two to ignition swith all
check good. main fuse ok, I have power going to ignition and back out.
post #7 of 9 (permalink) Old 05-20-2010, 07:40 AM
start at the panel that is not working and work back from there until you find power or a bad ground ,sounds like a bad connection or a switch problem,it is just going to require some hunting.
post #8 of 9 (permalink) Old 05-20-2010, 11:54 AM
Chavisimo's Avatar
Is it a digital LED display dashboard or an analog dashboard? I would assume an analog since the bike is an 89 model. If analog, do the RPM and MPH dials work? If they do, then maybe its just a light bulb gone out on the dashboard.
VROC Number: 31246
2003 Kawasaki VN750 SOLD
2006 Honda VTX1800C
Chavisimo is offline
post #9 of 9 (permalink) Old 05-22-2010, 09:20 AM
Did you remedy the problem? Sounds like the ignition switch to me or maby a bad ground do you have a manual?
cdaddy is offline
