Head Light - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 05-12-2010, 08:53 PM Thread Starter
Head Light
Hey All,
So I had pretty much got my bike right were I wanted it for the summer, and I thought to myself, "I bet my light would be brighter if I polished the inside of the lens up a bit," so I took the headlight off, polished it up, put it back on, and now it won't come back on!
I've replaced the bulb and the fuses are ok. Any thoughts? Prolly a short in my wiring huh? I know nothing about electrical. Any advice is welcome.
New Vulcan Rider
New Vulcan Rider is offline
post #2 of 17 (permalink) Old 05-13-2010, 12:58 AM
Check the bulb filaments visually and with a couple of jumper wires to to a battery, to be sure it is good.
Check the headlight connectors with a test light or multimeter for continuity, then trace back thru the wiring harness to every junction or splice until you find power.
post #3 of 17 (permalink) Old 05-13-2010, 05:32 PM
ronbo43
ronnbo43's Avatar
i would also check ground to headlight just a thought
ronnbo43 is offline
post #4 of 17 (permalink) Old 05-13-2010, 09:11 PM
What everybody else said about finding the problem, but I'm not getting the part about polishing the lense. I'm assuming you mean the inside of the lense? Even removing the bulb only leaves a small hole in the headlight assembly, how did you reach the lense? I would be afraid of messing up the chrome stuff on the reflector trying to do that. With the bulb in place, it is virtually a sealed unit, so nothing inside should be dirty. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #5 of 17 (permalink) Old 05-14-2010, 01:10 AM
I think I know what he is getting at Jerry. My glass lens is kinda cloudy, like it has a white film inside it. How it gets that way I do not know ,nor do I know how to clean it.If any body has a magic trick to clean the glass without damaging the reflector let me know.
post #6 of 17 (permalink) Old 05-14-2010, 02:00 PM
dirtrack650's Avatar
Does our VN have a headlight relay? If not, adding a relay would make our light slightly brighter and might last longer...
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #7 of 17 (permalink) Old 05-14-2010, 02:10 PM
DT
Yes,it is internal to the JB and is activated by one leg of the stator sending voltage to the JB,as the engine cranks over.
post #8 of 17 (permalink) Old 05-17-2010, 09:46 PM Thread Starter
I believe the problem is with the reserve lighting switch. Will I have to replace it? Do ya'll know if the part is specific to each bike model, or would one for say a 1982 Kawasaki KZ750 H3 LTD 750 work? Just wondering because one is on ebay and new the part costs 115 bucks. Thanks.
post #9 of 17 (permalink) Old 05-17-2010, 10:33 PM
Big Dumb Viking
asbrand's Avatar
Send a message via AIM to asbrand Send a message via MSN to asbrand Send a message via Yahoo to asbrand
Did you check everything with a multimeter yet?
-Az
http://www.asbrand.com
1989 Kawasaki Vulcan 750
Upgrades so Far:
Analog Voltmeter
PFIII Windshield
RAM GPS Mount w/Garmin GPS
Cigarette Lighter Power Adapter
Saddlemen's Classic Explorer Seat
Pro-Tac Driver's Backrest
LED Tail Light
LED Rear Turn Signals
Luggage Rack
Storage Trunk
Engine Guard w/Highway Pegs
Radiator Grill Cover
Turn Signal Relocation Bracket
Saddlebags
Floorboards
asbrand is offline
post #10 of 17 (permalink) Old 05-18-2010, 03:31 AM Thread Starter
asbrand, yeah I did. Had a friend who knows a little more about electrical help me a bit. From what I understand, the ground was good, but we weren't getting power. We created a circuit by connecting the multimeter to the fuse box and connecting that directly to the headlight. When we did that it turned on and would stay on after we disconnected the multimeter, but when we would turn the bike off it wouldn't come back on when the bike was restarted. We think somehow the lighting reserve not functioning properly disrupted the circuit.
