Gigantic Battery - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 05-11-2010, 03:08 PM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
Gigantic Battery
I have been talking about it well today i finished building the battery box. I have managed to shoehorn an SC30LFA 28ah 445cca into the vulcan. Here are pics of the new battery box. It still needs undercoated before it is installed. Many thanks to Hizzo3 for being the first to do this it was his idea. Sorry the pics aren't great but i took them with my phone.
ID:	2751   Click image for larger version
ID:	2752   Click image for larger version
ID:	2753   Click image for larger version
ID:	2754   Click image for larger version
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #2 of 18 (permalink) Old 05-11-2010, 07:08 PM
Mushu's Avatar
Send a message via MSN to Mushu
I'm going to ask a really dumb question but it's simple... WHY?
Looks supercool the battery cradle... really nice job...
93 VN750
R/R Relocation to the front
Pirelli MT66 Tires soon to be mounted (only after 14 years...)
Mushu is offline
post #3 of 18 (permalink) Old 05-11-2010, 08:37 PM
The bigger the battery the better, if it will fit. Every vehicle I have ever seen came with a battery that was marginal for it. If you replace the battery, get the biggest battery you can squeeze into it. Unfortunately that is not an option with many bikes. The Vulcan 750 seems to have a starter issue. Even when connected to a car battery, it will not turn over nearly as fast as I think it should. My EX500 turns over more than twice as fast. It sounds like the Vulcan starter is dragging, which is probably the cause of many of it's starting problem complaints. I have a Peterbilt battery in my Ford pickup. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #4 of 18 (permalink) Old 05-11-2010, 09:29 PM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
Well said Jerry I plan on adding the accel super coil setup since my coils test bad Tim is winding my stator, and I am replacing the r/r with the shindengen FH012AA so i figured the battery was all that was left. go big or go home. I have a friend who works for an electric motor repair shop who says he can look at the starter if it still doesn't spin up fast enough. Tomorrow i will post pics in the bike after the undercoating dries.
34k so far
coastered
spline lube
TPE stator
post #5 of 18 (permalink) Old 05-12-2010, 12:39 PM
That's a big ass battery there. Me likey.
Chiron is offline
post #6 of 18 (permalink) Old 05-12-2010, 04:48 PM
flitecontrol's Avatar
Would also appear to this electrical dunce that having a bigger battery will carry you farther towards home if your voltmeter should detect charging issues. But I've been wrong before.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #7 of 18 (permalink) Old 05-12-2010, 05:40 PM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
that is correct ths the 28ah capacity twice that of the stock size.
34k so far
coastered
spline lube
TPE stator
post #8 of 18 (permalink) Old 05-12-2010, 11:00 PM
skalding's Avatar
That almost qualifies it as an electric vehicle!
Scheherazade
'86 VN750
MF Battery, Iridium Plugs, RR relocated, Voltmeter, 170/80/15 Kenda Kruz rear tire, DIY Samsonite hard bags, DIY shaved seat with Beaded seat pad ('cause that's how I roll) and the dreaded STATOR CHANGE.
Shining Black Bess '86 VN750, retired for parts after a fried stator and being knocked (kee-runch) in her parking spot.
skalding is offline
post #9 of 18 (permalink) Old 05-12-2010, 11:05 PM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
if i run out of gas i will put it in fifth and run on the starter.
34k so far
coastered
spline lube
TPE stator
post #10 of 18 (permalink) Old 05-13-2010, 11:59 AM
dirtrack650's Avatar
I agree... I got pissed off a few weeks ago with the starter so I jumped my vn with a car battery and it started right up. 10.5 compression in a V twin? bet the starter is not strong enough to crank the way it should so it zaps too many amps from the system.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
Tags
battery
