Gigantic Battery - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 18 (permalink) Old 05-13-2010, 02:43 PM
I must every year to buy a new battery.
Serbianrider is offline
post #12 of 18 (permalink) Old 05-13-2010, 03:52 PM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
you need to replace it with a maintenence free battery. i was getting 2-3 years with a maintenence free battery
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #13 of 18 (permalink) Old 05-13-2010, 04:03 PM
I got almost 4 years out of a WestCo battery. I may get even more out of the one I have now, since I started using a battery tender. My first one went dead several times. I'm not sure about these AGM batteries, but when a typical lead acid battery goes dead, it does considerable damage to it, and reduces it's capacity. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #14 of 18 (permalink) Old 05-13-2010, 04:05 PM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
its the same with the agm my first one i left over winter no battery tender and in the spring dead it wouldnt hold a charge after i charged it.
34k so far
coastered
spline lube
TPE stator
post #15 of 18 (permalink) Old 05-13-2010, 04:49 PM
Columbus, Ohio
jimkonst's Avatar
I would like to hear how the bike handles the extra weight. Slow, tight turns might be a lot less stable. Straight down the road should be more stable. Tell us if it is noticeable.
Jim
'95 Kawasaki Concours
Sold my Vulcan
I do LOTS of dumb stuff. Riding is only one of them.
jimkonst is offline
post #16 of 18 (permalink) Old 05-13-2010, 04:53 PM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
the battery only weighs 20 lbs it wont be as bad as when i load the saddlebags when i am traveling. but then again i may not notice because i weigh 300lbs myself.
34k so far
coastered
spline lube
TPE stator
post #17 of 18 (permalink) Old 05-13-2010, 04:58 PM
dirtrack650's Avatar
I wet-nursed a Sears DieHard Gold wet cell for 7 years in my VN and it's still going strong in my XS650 Yamaha 3 years later (w/o electric start).
If you maintain a good quality wet cell, they work just fine. I got tired of pulling the seat every 2-3 weeks to check the battery levels. I flip up the seat on my 650, check levels, attach the tender, and it's happy.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #18 of 18 (permalink) Old 05-14-2010, 02:35 AM
everything is ok as you said, but here is hard to find good quality battery
Tags
battery
