replacing stator, what else should be done? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 05-11-2010, 02:58 PM Thread Starter
I've got almost 13K on my 2003 Vulcan and the stator needs replaced. What else should be done while I am involved with that? Maybe a clutch rebuild kit? I have noticed an occasional growl from the clutch when I let it out, but only when it is cold, and it sounds like it is coming from the left side of the engine, from the riding position. Maybe lube the spline? I'd appreciate any input.
troy76 is offline
post #2 of 14 (permalink) Old 05-11-2010, 03:11 PM
MANIC MECHANIC
vulcanjoe's Avatar
Check the vulacn verses for the coffee grinder noise. while you are in there you might as well replace your balance dampers. there are several threads on here about how to do this.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #3 of 14 (permalink) Old 05-11-2010, 03:14 PM
Definitely lube the splines.
Clutch should be OK, unless you are worried about the "Coffee Grinder" noise (that's common on Vulcans and doesn't cause any damage) unless you go with heavy duty springs on the clutch.
With those miles and age of the bike, everything else should be OK. Wouldn't hurt to check the condition of the dampeners, but again, I'd think they should be OK.
Do ya have a maintenance free battery?
post #4 of 14 (permalink) Old 05-11-2010, 03:36 PM
93VN750's Avatar
Kinda young for dampers, but check them while you're in there. Like Hyper said, spline lube for sure, MF battery for sure.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #5 of 14 (permalink) Old 05-11-2010, 06:02 PM
There is a tie rod between the shift lever shaft and the change lever shaft in the external shift mechanism that was seriously under engineered in the early bikes. It has been superseded by a stronger one now. I don`t know what model year the change was made, but you might want to research that, and change it out if the early one is still in your bike. The light duty one will fail sooner or later.
Lube the front bevel gear splines and U-joint too while it is easily available.
post #6 of 14 (permalink) Old 05-14-2010, 01:55 PM Thread Starter
Thanks for all the input. I'll definately lube the splines and check the dampers while I am in there. I am going to order the stator from Tim Parrott, he seems to be a dependable supplier, comments?
troy76 is offline
post #7 of 14 (permalink) Old 05-14-2010, 05:04 PM
Tim Parrott has an excellent reputation on here and this bunch doesn't hand out complements lightly.I don't know if you want to wait but I would contact him and send your stator for the heavy duty rebuild.I personally haven't dealt with Tim but he may have an exchange deal,I would call him up and find out.For sure do not buy a cheap Chinese built stator,with stators it appears you get what you pay for.And your bike is too new for the shift rod problem,I think that was taken care of after the first few years.
post #8 of 14 (permalink) Old 05-15-2010, 10:55 PM
When I did my stator, I took all of the air filter stuff off. Just put on 2 pod filters from Emgo instead of K&N's, alot cheaper and they seem to be working good. Eaiser to get to things and looks nicer. Not sure about the new stator and rr that I put on. Might be having to replace them again this year
tprender is offline
post #9 of 14 (permalink) Old 05-16-2010, 01:30 AM
Glenn C.
gcextreme's Avatar
You should take pics of the stator replacement and do a write up... if no one else has... and if someone else has, send me a link to it... I dont know when i am going to have to do a stator replacement, but i would like to be prepared.
I have a 2001 vulcan 750 i just rolled 11000 on it, bought it 2 years ago with 6800 on it. Did the spline lube, got a sealed battery, hopefully nothing else raises its head soon.
Glenn C
Alexandria, MN
My VN750 Page
VN750 Stator Plates and Products
2001 Kawasaki Vulcan VN750
1986 Kawasaki Vulcan VN750 (being restored)
1986 Kawasaki 454LTD (being restored)
1985 Kawasaki 454LTD (being restored)
gcextreme is offline
post #10 of 14 (permalink) Old 05-16-2010, 02:00 AM
dirtrack650's Avatar
Check and clean your starter motor. Lots of folks here complain of hot start problems and I believe one of the problems is the starter.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
