Starter Lock Out Switch help needed - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 41 (permalink) Old 05-01-2010, 03:54 PM Thread Starter
What is the starter lock out switch and where is it located?
post #2 of 41 (permalink) Old 05-01-2010, 04:26 PM
the doctor
billryx's Avatar
could be the 3 wire switch on the clutch perch
bringing together
a dead
'86 VN750
"it's alive":"krechure"
billryx is offline
post #3 of 41 (permalink) Old 05-01-2010, 04:44 PM
The one at the stand. Or the on/off switch.
post #4 of 41 (permalink) Old 05-01-2010, 04:47 PM
Yup, that is what a note I wrote some time back on the wiring diagram in my Clymers manual says too.
post #5 of 41 (permalink) Old 05-01-2010, 04:56 PM
MANIC MECHANIC
vulcanjoe's Avatar
how are things down there in big orange country.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #6 of 41 (permalink) Old 05-01-2010, 05:01 PM
On the wiring diagram those are identified specifically as the "Side stand switch" and the "Engine stop switch."
The starter Lockout switch contacts G and Y/G when the clutch is released; B/Y and Y/G when pulled in.
post #7 of 41 (permalink) Old 05-01-2010, 05:17 PM Thread Starter
I was thinking it was the clutch safety switch, thanks guys...
post #8 of 41 (permalink) Old 05-02-2010, 10:00 AM Thread Starter
ok here's the deal, I'm rewiring my bike, I tossed the JB, the Reserve Lighting Unit, the stock ignition switch, along with all the safety switches (for the time being). Here is my wiring diagram how I have it wired right now.
the problem is I am not getting spark. The Coils and the pickup coils test good, but I think that I have a problem with the IC Ignitor Box. I am getting ground feed back through the red wire that runs to both coils. Also, for the pickup coils, is the top coil front cylinder or rear cylinder?
post #9 of 41 (permalink) Old 05-02-2010, 12:13 PM
the doctor
billryx's Avatar
slim red & black is #1 and red & green is #2. The switch wire should not float it is either high (+12v) or low (goes to ground) I don't remember which! maybe somebody else might known.
bringing together
a dead
'86 VN750
billryx is offline
post #10 of 41 (permalink) Old 05-02-2010, 01:20 PM
i attached the wire diagram for my system. i had to make my own control box to work with out the reserve lighting unless you can get a euro one. the color codes i used are just colors i used myself and do not match kawi untill were it show to meet the ic and charging sys if you need help deciphering my cryptic code just pm me
Harley sportster fenders
custom raked front end
custom exhaust
vn800 tank and guages
modified seat and recovered
rear frame chopped
custom wiring harness
airbox removed
hzhardy is offline
