Ant colony in meters - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-01-2010, 03:35 PM Thread Starter
I was wondering if anyone has taken the meters apart to the point of removing the tach out of the white housing. There is a metal ring that has been pressed around the entire thing and I'm sure that I'll tear the thing up when prying at it. I am working on a bike that had sat for a couple years and an ant colony decided it would be a good home. I found them in the air cleaner, meters, harness, trunk, and behind the head light. They were able to get inside the meter and made quite the mess. I was hoping to get into it and clean out the remainder of an ant colony and also clean the plastic lens.
marc0011 is offline
post #2 of 5 (permalink) Old 05-01-2010, 03:58 PM
I was able to take the ring off my tach on my '85 VN700. I used a small screw driver and pried the ring little by little. It took me at least 30 minutes to go around the whole thing. I was able to put it back together and it didn't look all that bad.
sethchr16 is offline
post #3 of 5 (permalink) Old 05-02-2010, 10:05 AM Thread Starter
Thanks for the response. Guess I'll have to be very gentle and open the thing up.
marc0011 is offline
post #4 of 5 (permalink) Old 05-02-2010, 03:17 PM
Search Goddess
Dianna's Avatar
Careful of the edges as you work on it too as they can be razor sharp and will do a number on your hands. Slow and steady and lots of patience!
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #5 of 5 (permalink) Old 05-02-2010, 03:58 PM
flitecontrol's Avatar
If you bugger up the gasket/big O ring, I've got one.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
