clear headlamp - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 05-01-2010, 01:42 PM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
Question clear headlamp
i was wondering if anyone had found a clear replacement headlamp for our bikes or something that can replace the assembly fairly easy.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #2 of 12 (permalink) Old 05-01-2010, 01:58 PM
dirtrack650's Avatar
Right here and on sale too!
http://www.jcwhitney.com/seal-beam-h...p2003804.jcwx#
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #3 of 12 (permalink) Old 05-01-2010, 05:00 PM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
thanks Dt i hadnt thought about using the car conversion kits. and i know on gypsy's old site the kury 7 inch wouldnt fit the housing without cutting the ring and welding it back around it.
34k so far
coastered
spline lube
TPE stator
post #4 of 12 (permalink) Old 05-02-2010, 12:28 AM
Not sure about this, but I read somewhere a while back that auto bulbs and MC bulbs are not the same. Auto bulbs supposedly won`t take the vibration of a bike. Does anyone else know about this?
post #5 of 12 (permalink) Old 05-02-2010, 12:39 AM
VN750_DawgsFan's Avatar
Lance has found that cleaning the lens with Simple Green and baking in the oven for a while works great for getting it factory clear. I know from personal experience because he did it to mine. You'll have to PM him about it though for his secret remedy.
Or are you talking about the bulb? I just went to Walmart and bought the Sylvania Sliver star H4 60/55W for mine a while back and haven't had an problems out of it.
My daily ride
Metzler ME880s
NGK caps, wires and Iridiums
Coasters (made by Lance328), earshave and rejet with screws turned out 3 turns
Volt gauge w/ custom mounting cup by Lance328 wired into headlight bucket 13.5v-14v
National Cycles Plexistar 2 windshield
DEKA battery
Mutazu GA Black hard bags w/ custom support brackets and relocation brackets made by Lance328
Custom lowers made by Lance328
Vance&Hines Cruzer exhaust pipes
H.I.D. Conversion kit
VN750_DawgsFan is offline
post #6 of 12 (permalink) Old 05-02-2010, 01:08 AM
Columbus, Ohio
jimkonst's Avatar
What did you pay for the bulb? I just bought the bulb specified in the manual and paid nine dollars for it. It is a lot brighter than my old bulb was, but I am sure the Sylvania Silver Star is better.
Jim
'95 Kawasaki Concours
Sold my Vulcan
I do LOTS of dumb stuff. Riding is only one of them.
jimkonst is offline
post #7 of 12 (permalink) Old 05-02-2010, 02:49 PM
10 yr old
I bought my bike as salvage in Y2K, replaced the bulb with cheap-o H4 ($8.99) and it's still burning. I would like to try the HID conversion some day with the clear lens.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #8 of 12 (permalink) Old 05-02-2010, 03:15 PM
Search Goddess
Dianna's Avatar
I've got the clear lens auto headlight along with an HID conversion and no problems over the last two years with the set-up.
I don't have to worry about headlight bucket depth though since I have the fairing. However.. I do know that a Suzuki (650 I believe) headlight bucket will accommodate the auto headlight and it is a side mount setup. The main problem with an auto headlight is they are deeper then our OEM headlights, hence the need for a deeper bucket.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #9 of 12 (permalink) Old 05-02-2010, 07:41 PM
Lebanon, NJ
Hiker's Avatar
The Sylvania Sliver star H4 60/55W is much brighter and wider than stock. I use it and love it.
https://www.amazon.com/s/ref=nb_sb_n...2F55W&x=9&y=19
They do burn out quickly, (I believe 50 hours) although I'm in my 3rd year with one I'm planning on replacing it with a new one and keeping the old one as a spare.
Hiker is offline
post #10 of 12 (permalink) Old 05-02-2010, 10:37 PM
cglennon's Avatar
Sylvania SilverStar bulbs can be a GREAT value, especially the newer Ultra version.
Sylvania runs lots of rebates and coupons on these bulbs, but usually only on the set of auto H4 Silverstar Ultra bulbs (not the ST version). With a rebate/coupon these bulbs become a great value based on the increased visibility and quality of light produced. Yes, even Sylvania specs indicate they burn out faster than conventional bulbs (which they do). However, 2 years ago I purchased auto SilverStar Ultra auto H4 bulbs (model 9003/HB2) and took advantage of the $10 rebate at that time (got a good price on Amazon w/free shipping - $18/pair). Rebates are a pain in the butt, but they eventually sent a $10 check. I figured that the first bulb wouldn't last long due to vibration, so I would have the second bulb ready as a backup. It has been 2 years and still first bulb is still running strong, but only ride a few thousand miles a year. I still have the second SilverStar Ultra and the original OEM bulb on standby, waiting for the first to burn out.
Not a bad value so far.
If you can find the auto H4 bulbs on sale (i.e., $20 or less) and Sylvania is running one of their rebates (usually in the fall), then I think that the pair of auto H4 bulbs is a great value.
Chris Glennon - Portland, OR
cglennon is offline
Tags
clear , headlamp
