another charging problem... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 04-28-2010, 08:49 PM Thread Starter
0.62 volts are coming out of the rr. on the brown wire.. the chart says it should be 0.2 or less. anybody have any idea what connections i should check and where they are located? The stator checked out fine and i am hoping the rr is ok also and its just some connection issue. symptoms include intemittant charging when system is cold but nothing when it heats up.
mkontax is offline
post #2 of 8 (permalink) Old 04-29-2010, 10:39 AM Thread Starter
i am ordering a new rr........its due for a replacement anyway.....if it turns out not being a the rr.......then at least i have a spare just in case......
mkontax is offline
post #3 of 8 (permalink) Old 04-29-2010, 12:13 PM Thread Starter
so the yellow wires coming out of the stator should be fused....hmmmm....wouldn't a thermal protection switch be more suitable? its just a thought.....i am sure someone has thought of it already and there is a good reason why it won't work.....
mkontax is offline
post #4 of 8 (permalink) Old 04-29-2010, 12:17 PM
No, I don't believe that they have any fuses on them. Some guys on the forum have tried fusing them. But I think the conclussion was that the fuses served no real purpose.
post #5 of 8 (permalink) Old 04-29-2010, 12:35 PM
fergy's Avatar
I agree with NOT adding fuses to the stator wires. Best thing there is to make sure the connections are clean and tight, or to trim back the connections and solder the wires and heat shrink them individually, keeping the three wires separated from each other. Never bundle them together as the heat that they generate can be pretty hot and can exponentially heat the bundled group and cause failure.
Have you gone through the procedure to test your charging system? Here is the link to the electrosport document you should follow: http://www.electrosport.com/technica...ng-diagram.pdf
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #6 of 8 (permalink) Old 04-29-2010, 02:25 PM
What chart is that? The brown wire voltage should be above 12V with ignition on and around 14V with engine running.
pappa is offline
post #7 of 8 (permalink) Old 04-29-2010, 02:51 PM
X2 pappa
post #8 of 8 (permalink) Old 05-04-2010, 07:14 PM Thread Starter
its fixed....another bad rr.....bought it at pat's small engine...it was fast prompt service with a great price....made in argentina of all places. the unit seems to be have heftier heat sinks...i don't know if it is any good as time will tell....
mkontax is offline
