volt meter bouncing - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-27-2010, 12:58 AM Thread Starter
stohlbet's Avatar
volt meter bouncing
My last ride I noticed that my volt meter was bouncing all over the place in it's readings. I noticed that it would peg out in the red and then drop below the green. The bike seemed to run fine but I was wondering if there's a need to be concerned and what might be a cause.
stohlbet is offline
post #2 of 4 (permalink) Old 04-27-2010, 09:44 AM
GIMPYRDR's Avatar
This is good reason the voltmeter is a good mod, to let you know when there is a problem. I would start by checking all my electrical connections, cleaning them, and using the dielectric grease. Next, test the stator and R/R. There are several threads explaining how to dod this as well as instructions in the verses.
2005 Vulcan 750
Black and Silver
Saddlebags
OEM Hghwy Bars
O-ring Footpegs
OEM Luggage Rack
V&H Exhaust System
TOC ACCT Rebuild
Die Hard Gold AGM MFB
Spline Lube every tire change
VN750 #4393
VROC #31065
TexasVROC
GIMPYRDR is offline
post #3 of 4 (permalink) Old 04-27-2010, 09:59 AM
fergy's Avatar
And I'd add, check all your grounds, clean and dielectric grease them. Sure sounds like a loose connection.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #4 of 4 (permalink) Old 04-27-2010, 11:19 AM
cglennon's Avatar
Happened to mine once. The battery bracket was not making good contact with the new AGM battery (it was a tad smaller than the OEM wet cell). The new battery moved back and forth, just a small amount. Apparently, it was enough movement to loosen the battery cable, over time. First indication was the volt meter needle bouncing, then sputtering.
Like the other posts indicate, check all connections.
Chris Glennon - Portland, OR
cglennon is offline
