thinking of trying the ce-602 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 68 (permalink) Old 04-23-2010, 09:22 AM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
Question thinking of trying the ce-602
i am thinking of trying the cycle electric ce-602 r/r it is a non shunting type. does anyone have any thoughts or expierence on this.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #2 of 68 (permalink) Old 04-23-2010, 09:49 AM
darrelc5's Avatar
Abso-frickin'-lutely! The specs say it's rated at 45A and this is exactly the type of series regulator we've been looking for. I agree with the writeup here:
CE-602 Regulating Series Rectifier
that is will preserve the stator by reducing the heat produced. Heat in the stator is a function of current through the windings and on the stock VN750, current is a function of RPMs; this R/R will change that to being a function of current load in the bike, which is often less than the max that the stator can produce.
Rock on!
Darrel
'03 Vulcan 750 (90k miles)
-Corbin Seat
-V-Force Windshield
-LeatherLyke Touring Bags
-Chrome Luggage Rack
-Headlight Modulator
-Brakelight Flasher
-MF Battery
-Heads-Up Voltage Monitor
-Replaced Stator (9,000 and 16,000 mi.)
-Oil-cooled Stator Mod (photos)
-Replaced and Relocated R/R
-Greased rear splines
-Fused Stator (photos)
-Metzeler ME880 Marathon 170/80-15 (Rear), 110/90-19 (Front)
-TOC MCCTs installed
-Headlight Relays
SOLD - 2013
darrelc5 is offline
post #3 of 68 (permalink) Old 04-23-2010, 05:27 PM
Catchemall's Avatar
This should solve 99% of all of the Stator/ Regulator problems.
I was on the CE site yesterday and saw this and meant to ask if anyone else had seen it or tried it; Now you need to find someone to wind you a stator with more output and you can run all the lights you want; maybe even A/C;;;;;;
Don't understand why this has not been tried already; most automotive alternators have the regulator and rectifier built in and just one wire (+) going to the battery.
Catchemall is offline
post #4 of 68 (permalink) Old 04-23-2010, 05:39 PM
looks sound to me,what about price?
post #5 of 68 (permalink) Old 04-23-2010, 07:36 PM
This won't work... the Dyna uses a single phase stator... (2 stator leads)... on the Cycle eletrics page for the 600 series, none of those models will work... I have searched every model listed on that page and all are single phase stators. And all the VR's listed have the rectifier built into the VR
OK every HD model that I could find a diagram for uses a single phase stator. and these won't work with our bike. Pre 78's might be able to work since I couldn't find info on them.
I am not sure what you guys are trying to do, If you guys were fallowing my train of thought to find a 2 piece set up so you could replace just the VR when it fails, or if you are trying for a R/R set up... if you are looking for a beefy R/R, send Tim Parrot an email, he has one in stock for 90 bucks (includes shipping) that is rated at (iirc) 80 amps. its not a direct bolt on part, but will work with a home made mounting bracket.
post #6 of 68 (permalink) Old 04-23-2010, 09:51 PM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
04-05 dyna used three phase you have to use the ce-602 click on the write up on darrel's post
34k so far
coastered
spline lube
TPE stator
post #7 of 68 (permalink) Old 04-23-2010, 10:14 PM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
slightly prohibitive 175-200 range but if it handles current without as much heat and doesent fry stators seems an ok price
34k so far
coastered
spline lube
TPE stator
post #8 of 68 (permalink) Old 04-24-2010, 10:14 AM
this might work, just be sure to splice the brown wire to white... otherwise parts of the jb might not work.
post #9 of 68 (permalink) Old 04-24-2010, 10:35 AM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
i was going to splice in the brown and red and then run straight to the battery to charge
34k so far
coastered
spline lube
TPE stator
post #10 of 68 (permalink) Old 04-24-2010, 10:38 AM
Several models of harleys used a 3phase permanent magnet systems. I just recently found a LOT of talk about this same issue on other bikes where the R/R is the weak link. The general conclusion is the best upgrade is the Shindengen FH012AA MOSFET "series" style r/r that's used all over the place on newer bikes/atvs/watercraft. It handles up to 50 amps and puts out ~14 at all rpms including idle. The main thread people have been referring to from all manner of forums (from Triumphs to honda chops) is here:
http://www.triumphrat.net/speed-trip...r-upgrade.html
They seem to be used on quite a few places. A few specific bikes and yamaha part numbers are mentioned in that thread, but they have become so popular it can be hard to find them now. The best place I have found bike specific kits and a universal option is here:
http://roadstercycle.com/Shindengen%...rade%20kit.htm
$119 for the kit including connectors.
I'm just trying to decide between the CE unit and this one.
Chiron is offline
Tags
ce-602 , r/r
