Starter motor wont start - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 23 (permalink) Old 04-19-2010, 06:08 PM Thread Starter
xavier's Avatar
When I press the start button nothing happens. My dash turns on. So do all my ambers and brake lights turn on, but the starter button does nothing. I can get the starter motor to turn if I touch the Y/R wire to positive cable on the starter solenoid relay. I was thinking that maybe my ignition wasn't working so i pulled it out and all the solder points looked good and I stretched the springs alittle.
so far ive check to see if I get voltage from the w/r wire connecting from the starter solenoid relay to the plug on the JB. I get voltage on that one.
when I tried checking for voltage from the y/r wire connecting from the starter solenoid relay to the plug on the JB. I got nothing. I did check the y/r wire for connectivity and it has connectivity so i unplugged the wire and just checked voltage on the tab that the wire connects to from the solenoid, no voltage at all. key turned on or off
I also checked for voltage on my main fuse connectors and I only get voltage from the top connector and not the bottom.
I did these checks based on suggestions from the thread "My turn". Im not sure what to check next
xavier is offline
post #2 of 23 (permalink) Old 04-19-2010, 08:10 PM
Crobins365's Avatar
I tihnk there's a way to bypass the relay so you can determine if that's your problem. Hopefully someone who has done that will pipe up shortly!!
C
Crobins365 is offline
post #3 of 23 (permalink) Old 04-19-2010, 10:29 PM
the yellow/red stripe should have power with the starter button pressed in and key in on Position with the transmission in Neutral and side stand down
post #4 of 23 (permalink) Old 04-19-2010, 10:42 PM Thread Starter
xavier's Avatar
I just tried the bypass to the ingintion per instructions on previous post. I disconnected the brown wiring connector, and on the wiring harness side, jumped the white with black stripe wire to yellow with red stripe wire. nothing happened.
How can I check if the engine shut off switch is working? If I understand correctly I should be getting voltage to the y\r wire on the starter relay when the engine shut off is on? that seems to be the only thing missing for me I im not getting power to that y\r wire. I only have half of my main fuse getting power.
thats a guess from a person who really knows nothing but has been rereading this over and over.
xavier is offline
post #5 of 23 (permalink) Old 04-19-2010, 10:47 PM
X2 on what denny said... so next question is, does pin 11 0n the jb have power?
post #6 of 23 (permalink) Old 04-19-2010, 10:53 PM Thread Starter
xavier's Avatar
sorry but do you know what color wire that is?
also I wanted to check for continuity on ignition wires just in case but I dont know where the other wires like the blue/red, white/blue, orange/green, blue/white are. are they suppose to be on the jb?
xavier is offline
post #7 of 23 (permalink) Old 04-19-2010, 11:28 PM
ok wires on the ignition switch, for bike starting all you need to worry about are the white wire and yellow/red wire, the rest go to lights, look at your wiring diagram it shows you where every thing goes.
Blue White or blue yellow, can't tell in my pic... go to Flight's post and look at his JB diagram and look at the connectors,
post #8 of 23 (permalink) Old 04-19-2010, 11:47 PM Thread Starter
xavier's Avatar
on flights post it shows the 10 pin connecter, and on the top left corner I believe is pin 11. now on the picture it shows it should be a blue...maybe white stripe wire but i dont have a wire that color the only blue wire i have is solid blue and its on pin12. pin 11 is a black and yellow wire. I must be looking at this wrong.
dispite the color of wires I checked all of the wires on the 10 pin connector and the only pin that registered 12v is pin 9. A few others registered less than 1v
pin11=0 pin12=.07 pin13=.06 pin5=0 pin4=.05
pin15=0 pin9=12.5 pin() pin14=0 pin16=.45
xavier is offline
post #9 of 23 (permalink) Old 04-20-2010, 01:26 PM
The color markings in the wiring diagram match the actual colors of the wires on the 8-pin connector of the JB, but not all colors on the 10-pin connector match. At least on my bike there are two wires which are different color, and they both are in the starter circuit:
pin 11:
  • diagram says black
  • actual color is black/red
  • comes from start button
pin 12:
  • diagram says yellow/green
  • actual color black
  • comes from starter lockout switch
I would gladly try to help you, but don't dare suggest anything until this is cleared.
pappa is offline
post #10 of 23 (permalink) Old 04-20-2010, 05:08 PM Thread Starter
xavier's Avatar
ok so here is a picture of my switch. Its blurry but youll get the idea and you can see the colors
(pin11=black\yellow) (pin12=solid blue) (pin13=yellow\red) (pin5=solid black) (pin4=black\red)
xavier is offline
