Still having charning issues - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 23 (permalink) Old 04-19-2010, 08:48 AM Thread Starter
Ok, so I have replaced the regulator and still not its not charging. The stator was tested several times and that seems normal.
"check voltage on the brown wire at the r/r... if low, check voltage on pin 13 of the jb... if voltage is high then the diodes inside the vr could be burned out causing wrong trigger wire readings." Slim
I checked the volts at the brown wire and that was sitting just around 12ish even when revving the motor. I was unable to find pin 13. and what is a vr?
1992 Vulcan 750.
Ear shaved and re-jetted.
theone2043 is offline
post #2 of 23 (permalink) Old 04-19-2010, 09:22 AM
flitecontrol's Avatar
Voltage regulator?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 23 (permalink) Old 04-19-2010, 11:08 AM
With the engine running, at the r/r you should see:
Black/yellow wire: Below 0.5V.
Brown wire: Above 13V.
White wire: above 13V.
More things to check (with ignition off):
- Resistance from Black/yellow wire to battery negative terminal.
- Resistance from White wire to battery positive terminal.
Both should be less than a few ohms.
pappa is offline
post #4 of 23 (permalink) Old 04-19-2010, 12:15 PM Thread Starter
how do you check resistance? If the brown and white wires are below 13 v, what can be concluded? I think I tested the brown wire with the bike running and it was about 12.6, which was the same as the battery.
1992 Vulcan 750.
post #5 of 23 (permalink) Old 04-19-2010, 12:27 PM
Resistance is measured in ohms. On the meter, is usually designated by the Greek letter Omega (Ω). Hope this helps.
"Black Beauty"
Old Blue
post #6 of 23 (permalink) Old 04-19-2010, 12:34 PM Thread Starter
http://www.northerntool.com/shop/too...&ci_sku=163100
that is similar to the tool I have, when checking the battery I have it set to dcv 20 is that correct? What would I use to check for the resistance using this tool?
1992 Vulcan 750.
post #7 of 23 (permalink) Old 04-19-2010, 12:53 PM
Sorry, I have exhausted my limited knowledge of electronics! Someone else needs to chime in.
"Black Beauty"
Old Blue
post #8 of 23 (permalink) Old 04-19-2010, 01:20 PM
To check resistance with that meter, turn the dial to 200 in the section marked Ω (Ohms). Put the black (-) probe in the Common/ Ground position (bottom of the three positions). Put the red (+) probe in the V/Ω/mA position (middle of the three positions). Take following measurements and report the readings back here.
Chiron is offline
post #9 of 23 (permalink) Old 04-19-2010, 06:04 PM Thread Starter
Battery is sitting at 13v, tested the black/yellow and that was sitting around 11v, the white wire is in the 12's. All this was done at idle. The resistance for the black/yellow is at .6 and the white wire is at the same .6.
1992 Vulcan 750.
post #10 of 23 (permalink) Old 04-19-2010, 09:53 PM
you have 11V at the Black/yellow wire??? is that with black test lead on the MM to the wire and Red test lead to Battery +? or is that Black to ground, and red to wire?
