headlight - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 04-02-2006, 09:14 PM Thread Starter
headlight
light comes on when I turn key on, any suggestions, thanks alot, lee
lgower is offline
post #2 of 5 (permalink) Old 04-02-2006, 09:41 PM
I would think that a relay might be at fault but unless it is causing some sort of problem then I don't think it really matters.... but then again I am not an expert.
jdegreif is offline
post #3 of 5 (permalink) Old 04-03-2006, 03:22 PM
I think TADT....the headlight is supposed to shut off when you crank the engine and come back on when running...
jm1515 is offline
post #4 of 5 (permalink) Old 04-03-2006, 10:10 PM
Loran in Npvl IL's Avatar
Actually, the headlight is suppose to be off when you first turn the key from the off posisition to the on possition. After the engine turns over some, a relay will be energized and the headlight will come on.
On some Hondas, the headlight is connected to the starter button - if the starter button is pressed, the headlight is off - if the starter button is not pressed, the headlight is on.
Deuce (Loran Naperville IL)
2003 VN750
- Corbin seat w backrest
- Progressive suspension.
- Kury iso goldwing grips
2 1983 V65 Magnas
Loran in Npvl IL is offline
post #5 of 5 (permalink) Old 04-04-2006, 10:27 AM
"ya can't live forever"
artman's Avatar
What light are you referring to? If it's the white headlight indicator it may mean that a filament is burned out.
artman is offline
