Idea for r/r and stator longevity - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 04-11-2010, 11:46 PM Thread Starter
Has anyone tried installing a small fan, kind of like the ones in the computer, on the r/r?? And also running the oil through an oil cooler located so the radiator fan can blow air throught it?? The r/r fan could come on with the radiator fan. This idea would be for city riders.
post #2 of 13 (permalink) Old 04-11-2010, 11:56 PM
I have thought of the R/R fan idea... now to go along with your oil cooling... look up the oil cooled stator... i think those two ideas connected could make something very workable...
post #3 of 13 (permalink) Old 04-12-2010, 02:35 AM
dirtrack650's Avatar
I think using 20-50 oil and 4 liters like the books recommend and it's stamped on the engine case, may help keep the stator cool.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #4 of 13 (permalink) Old 04-12-2010, 10:45 AM
darrelc5's Avatar
Since the stator is supposed to be oil-cooled, it might benefit from more oil ON the stator. I modified a stator cover with a sight glass and observed the stator while the engine is running - there is barely a mist of oil circulating in that cavity, even at higher RPMs. That led me to route an oil line to spray the stator with engine oil. That was 35,000 miles ago and the stator coils are free of heat discoloration to this day.
Checkout: Further protection for your stator
Darrel
'03 Vulcan 750 (90k miles)
-Corbin Seat
-V-Force Windshield
-LeatherLyke Touring Bags
-Chrome Luggage Rack
-Headlight Modulator
-Brakelight Flasher
-MF Battery
-Heads-Up Voltage Monitor
-Replaced Stator (9,000 and 16,000 mi.)
-Oil-cooled Stator Mod (photos)
-Replaced and Relocated R/R
-Greased rear splines
-Fused Stator (photos)
-Metzeler ME880 Marathon 170/80-15 (Rear), 110/90-19 (Front)
-TOC MCCTs installed
-Headlight Relays
SOLD - 2013
darrelc5 is offline
post #5 of 13 (permalink) Old 04-12-2010, 09:10 PM
darrel, I went back and looked your oil plumbing system for cooling the stator over, and it seems a sound idea to me.
I like the second idea even better as it does not require pulling the engine.
In your edit about tapping into the connection for the oil line to the hydraulic lash adjusters, you seem to be describing the fitting in this picture with the oil pressure gauge attached:
http://www.flickr.com/photos/2339973...7605602927618/
Is this right?
I am somewhat leery of using copper tubing, as vibration will eventually work harden it and cause it to crack. Perhaps the short lengths you have used in your own bike`s internal cooling system, are not so vulnerable to vibration fatigue as longer pieces could be.
It would be interesting to install the sight glass modified stator cover onto your bike now, too see just how much cooling oil gets to the stator.
post #6 of 13 (permalink) Old 04-13-2010, 05:55 AM
KIMMERLING's Avatar
Totally. I will take one stator lubircator system please. How much?
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #7 of 13 (permalink) Old 04-13-2010, 05:24 PM
darrelc5's Avatar
Gordon, that's the fitting in the picture. I figure it would be better to connect there where the oil passage is much larger than downstream in the HLA tube.
First thing I did after putting the engine back together is test the oil pressure, which you can see in one of the pictures. Second was to mount the modified side cover and, man, oh man, there is a lot of oil flinging around in the flywheel cavity! The nozzles spray directly into the spinning flywheel, and it's rotation splashes it all over the stator.
A kit could be made up for the external tubing mod, and it should be pretty cheap when parts are bought in bulk. Somebody should do that....
Darrel
-Corbin Seat
-V-Force Windshield
-Brakelight Flasher
-MF Battery
-Headlight Relays
SOLD - 2013
darrelc5 is offline
post #8 of 13 (permalink) Old 04-14-2010, 03:30 AM
KIMMERLING's Avatar
I will contribute 100$ to the support and development of a stator lubricating/cooling system that would advance Vulcan 750's to the next level. This could have potential patent possibilities if someone perfected it.
Ventura guards
MadStadt mount
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
post #9 of 13 (permalink) Old 04-14-2010, 05:24 AM
its already been done...
post #10 of 13 (permalink) Old 04-14-2010, 06:11 AM
slim you need sleep, that is the post we are talking about. It is 3:10 am now, so I`m going to bed too. 8)
