My Turn - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 100 (permalink) Old 04-07-2010, 09:39 PM Thread Starter
flitecontrol's Avatar
My Turn
Well, after 8,000 trouble-free miles, my 55 mile round trip ended at 38 miles. At an intersection I allowed the rpms to get low and she died. Normally not a problem, but when I hit the start button, nothing. Thought I had hit the kill switch, but no it's in the run position. Then I notice there are no lights on the instrument panel. Turn the ignition switch on and off several (well, many) times, and still no lights.
So tomorrow when it's light, gona pull the seat and start looking for loose connections, blown fuses and put the meter on the battery. Yeah, kinda wish now I'd made a bracket for the voltmeter I bought a few months back, but it was more fun to ride.
Any suggestions on where to start?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #2 of 100 (permalink) Old 04-07-2010, 09:42 PM
Look for blown fuse and broken main battery cables.
Sorry about your trouble. I am going to redo my set up on my volt meter. I am going to use a relay and get my reading from the battery. Now I am getting it from the light circuit and I get lower reading than at the battery.
post #3 of 100 (permalink) Old 04-07-2010, 09:48 PM
The Professor
lance328's Avatar
[QUOTE=niterider;131419]Look for blown fuse and broken main battery cables.
And all ground connections.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 100 (permalink) Old 04-07-2010, 09:56 PM Thread Starter
[QUOTE=lance328;131421]
Yeah, gonna do that too. My son and I are taking a horse to a grandson who lives in Villa Ricca this Friday. If I don't get it figured out tomorrow, may load an iron pony in with the other one and come see you!
"Black Beauty"
Old Blue
post #5 of 100 (permalink) Old 04-07-2010, 10:00 PM
[QUOTE=flitecontrol;131422]
Batteries can go bad all of a sudden, not very often but it does happen.
post #6 of 100 (permalink) Old 04-07-2010, 10:01 PM Thread Starter
If that's al it is, nite, I'll be a very happy man!
"Black Beauty"
Old Blue
post #7 of 100 (permalink) Old 04-09-2010, 08:04 AM
Concert connoisseur
wib714's Avatar
hope its just the battery, bikes should only be allowed to break down in november/ december!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #8 of 100 (permalink) Old 04-09-2010, 10:17 AM
cglennon's Avatar
.. main battery cables.
Loose main cable has appended to me twice. Once due to the dealership testing the battery, but never reconnecting the cable and once on its own, due to movement in the battery. I shimmed the battery hold down bracket to eliminate the movement and put lock washers on the battery cables. So far, so good.
Chris Glennon - Portland, OR
cglennon is online now
post #9 of 100 (permalink) Old 04-09-2010, 11:34 AM
Most likely a bad connection (hot or ground) or a bad fuse. Could be a bad battery, But they usually give you some warning before they fail completely, unless an internal connection to one of the posts broke. Not likely a serious problem. Were you able to bump start it? Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #10 of 100 (permalink) Old 04-10-2010, 09:22 AM Thread Starter
Trailered it home.
"Black Beauty"
Old Blue
