question for lance - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 04-05-2010, 11:49 PM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
Question question for lance
in another thread you touched on the l.e.d. lights causing the r/r to have to burn off more juice. i was looking at having tim rewind my stator there is nothing wrong with the charging system on my bike. my r/r seems ok the bike is charging at 13.9v. when i put the bike back together i am degoating finally relocating my r/r and was thinking of doing hizzo's battery box mod to hold the 12v30 westco battery 30ah 350cca. basically i am asking if you would have the stator rewound or not and what are your thoughts on the 12v30 battery. as a side note i have no plans for driving lights. heated anything, gps or any other accessory i am going to put in a hid headlight and some auxillary l.e.d. brake lamps. thanks in advance. Drew
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #2 of 9 (permalink) Old 04-06-2010, 12:15 AM
The Professor
lance328's Avatar
The best thing you can do for the charging system is to relocate the R/R. unless you plan on adding a crap load of accessories the larger battery is not needed. As far as rewinding the stator that will depend on the AC output. below 40 AC volts I would rewind, 50-70 is normal @4000 rpm.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 9 (permalink) Old 04-06-2010, 12:19 AM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
that is at each phase correct. guess i will start it up before i pull it apart wednesday to replace the dampers. thanks again.
34k so far
coastered
spline lube
TPE stator
post #4 of 9 (permalink) Old 04-06-2010, 12:29 AM
The Professor
lance328's Avatar
All three phases two at a time, set mm on AC volts.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 9 (permalink) Old 04-06-2010, 12:37 AM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
i have done a lot with automotive charging systems (alternators) this is my first motorcycle charging system.
34k so far
coastered
spline lube
TPE stator
post #6 of 9 (permalink) Old 04-07-2010, 07:13 PM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
Thumbs up
HAPPY DANCE TIME!!!!
tested my stator according to the instructions found in an earlier thread
will only give one result per test all were consistant
stator to case 2.64 Mohm
across stator phases .8 ohm
68 Vac at 4k rpm
seems good to me thanks lance.
34k so far
coastered
spline lube
TPE stator
post #7 of 9 (permalink) Old 04-07-2010, 07:20 PM
The Professor
lance328's Avatar
68 Vac at 4k rpm
Everything looks good except the stator to case, should be open and no reading. It was probably the setting on the MM since you have high output.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 9 (permalink) Old 04-07-2010, 10:22 PM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
the meter i am using is a mac em710 it will even read resistance of the human body
34k so far
coastered
spline lube
TPE stator
post #9 of 9 (permalink) Old 04-19-2010, 12:00 AM Thread Starter
MANIC MECHANIC
vulcanjoe's Avatar
figured i would throw up a couple of pics of my stator and see what you think
ID:	2689   Click image for larger version
ID:	2690   Click image for larger version
34k so far
coastered
spline lube
TPE stator
Tags
battery box
