headlight lens - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 03-26-2010, 09:28 PM Thread Starter
Send a message via Yahoo to jdamato1
headlight lens
My headlight is fogged over pretty bad. Looking to replace the lens. Do I have to get this from Kawi ?
jdamato1 is offline
post #2 of 12 (permalink) Old 03-26-2010, 09:52 PM
The Professor
lance328's Avatar
Over time the inside gets cloudy, no need to replace. Remove the bulb an pour in some glass cleaner, ammonia or other cleaner and let set for 15 minutes. Rinse thoroughly with hot water and let dry overnight or put in oven @150* for 30 minutes and let cool.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 12 (permalink) Old 03-26-2010, 11:48 PM Thread Starter
ill try that tomorrow morning. Also My bike is hard to start but had the battery tested and it was fine. Had the starter tested and it seemed to be spinning slow. i WAS TOLD IT PROBABLY IS TIME. Is this a common problem and is it the starter. I can pop start it no problem.
jdamato1 is offline
post #4 of 12 (permalink) Old 03-26-2010, 11:51 PM
Look to ebay for a used starter or rebuilt kit.
post #5 of 12 (permalink) Old 03-28-2010, 02:27 AM Thread Starter
Found a used starter for 75.00 and the light trick worked great, rinsed it in vinegar than demin water
jdamato1 is offline
post #6 of 12 (permalink) Old 03-28-2010, 02:42 AM
The Professor
lance328's Avatar
I knew it would, please send $15.00 to: ME!! LOL
Glad to help!!
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 12 (permalink) Old 03-28-2010, 03:01 AM Thread Starter
ill take one of those covers and I also need the spring and washer that go in front of the oil drain plug between the screen and plug. Do u have it ?
jdamato1 is offline
post #8 of 12 (permalink) Old 03-28-2010, 03:03 AM
The Professor
lance328's Avatar
Give me 5 minutes and I will check on the spring and washer, BRB
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #9 of 12 (permalink) Old 03-28-2010, 03:16 AM
The Professor
lance328's Avatar
Just looked, drain plug but no spring and washer. Contact Crobins365 she should have them.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #10 of 12 (permalink) Old 03-28-2010, 03:16 AM Thread Starter
Do i need the spring ?
jdamato1 is offline
